00 Si needs new tranny
Old Nov 15, 2005 | 08:43 PM
HondaHeddie's Avatar
Default 00 Si needs new tranny...need advice
00 Si
Hydro clutch
what options are there to replace this tranny
$1k from the dealer just dont honk my horn
Old Nov 15, 2005 | 08:49 PM
EL Vap133's Avatar
Default Re: 00 Si needs new tranny...need advice (aal)
Buy a used one for about $500+.
Old Nov 15, 2005 | 09:14 PM
Default Re: 00 Si needs new tranny...need advice (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Buy a used one for about $500+. </TD></TR></TABLE>
ther are no 00 Si's in the junkyards around here.
what other trannies will fit?
Old Nov 15, 2005 | 09:27 PM
Siberian Husky's Avatar
probably get a really nice JDM b16a tranny with the LSD option for under that 1k that the dealer wants..shipping might be a biatch..but if LSD isnt a need..just get the tranny....or..get a gsr tranny and boost or motor...OR...just use the money to rebuild your tranny with your desired gears..OR..eat mcdonalds
Old Nov 15, 2005 | 09:37 PM
L8apex's Avatar
Default Re: 00 Si needs new tranny...need advice (Siberian Husky)
What exactly is wrong with your transmission that it requires a replacement? I'm in the process of rebuilding mine with new bearings, a new fifth gear, and LSD. It's almost as much as a used tranny but at least I know what's NOT wrong with it.
I'd hate to purchase a used tranny and diagnose/repair any problems it may have.
Old Nov 15, 2005 | 09:54 PM
vancoland's Avatar
yea...whats wrong with the tranny?...i heard that si trannies are pretty reliable. Theres tons of information if you ever plan to rebuild it yourself
https://honda-tech.com/zerothread?id=795700
Old Nov 15, 2005 | 10:01 PM
Default Re: 00 Si needs new tranny...need advice (L8apex)
4th is gone and 3rd is on its way
thanks for the link
Old Nov 16, 2005 | 09:07 AM
L8apex's Avatar
Si trannies are not THAT reliable, but a lot of it depends on driving style/ability.
Anyways, to repair the 3rd/4th gear, the synchros are on the same synchro sleeve on the mainshaft and if that's all you're planning to replace, you're looking at about $200 or so.
And if you want one, you can find an OEM LSD for about $300-400. It's gonna end up being slightly more than a new transmission but at least you already know what problems your particular transnmission has or doesn't have.
I got mine here:
http://cgi.ebay.com/ebaymotors...wItem
Old Nov 16, 2005 | 12:33 PM
bmoua's Avatar
true...even on the Ex its the same...mine grinds once in a while and pops out...my buddies ex tranny his 2nd gear was gone..he had to shift from 1st to 3rd gear. and now its dead.
Old Nov 16, 2005 | 12:54 PM
SkoundrelUSA's Avatar
cute little bastard
To answer your question any B-series transmission should work (Hydro Tranny from 00 Civic Si, 94-97 Del Sol VTEC, any 94-01 Integra)
But I wouldn't recommend mating the B16 with anything besides a B16 (99-00 Si, Del Sol VTEC) or ITR trans
Old Nov 16, 2005 | 01:09 PM
Default Re: 00 Si needs new tranny...need advice (SkoundrelUSA)
thanks
Old Nov 16, 2005 | 01:21 PM
.Beaver's Avatar
Bloody Beaver
this guy has a good deal on a tranny
https://honda-tech.com/zerothread?id=1421821
Old Nov 16, 2005 | 03:40 PM
vancoland's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L8apex &raquo;</TD></TR><TR><TD CLASS="quote">
I got mine here:
http://cgi.ebay.com/ebaymotors...wItem</TD></TR></TABLE>
does that lsd work with the stock b16 tranny s4c?
Old Nov 17, 2005 | 01:06 AM
L8apex's Avatar
Default Re: 00 Si needs new tranny...need advice (vancoland)
Actually no, you have to get an ITR or CTR ring and pinion.
Although I have been talking to the guy and he was expecting a JDM SiR LSD from an EK or an EG which use the same ring gear as a USDM S4C.
Old Nov 17, 2005 | 05:23 AM
95 RED CIVIC's Avatar
go with a GS-R tranny much more realible then the b16 my tranny did the same 2nd and 3rd gone but just get a JDM gs-r tranny with lsd for like idk a little over 1k
Old Nov 17, 2005 | 02:17 PM
L8apex's Avatar
Default Re: 00 Si needs new tranny...need advice (95 RED CIVIC)
I'm borrowing a GS-R tranny right now with my B16A and I wouldn't recommend it. 2nd through 5th are too tall for this engine's powerband.
Old Nov 17, 2005 | 02:19 PM
Louie_EM1
Guest
Posts: n/a
Replacing synchros at a professional is a lot more than what people think.
I suggest buying one used from a reputable seller, or buying a fresh brand new one from Honda.
Multi synchros can add up to half the amount of a brand new one.
And to answer your question, all B series is all gravy, they do differ in gear ratios however.
Old Nov 17, 2005 | 02:21 PM
dutchman5's Avatar
-<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 RED CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">go with a GS-R tranny much more realible then the b16 my tranny did the same 2nd and 3rd gone but just get a JDM gs-r tranny with lsd for like idk a little over 1k </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 RED CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">go with a GS-R tranny much more realible then the b16 my tranny did the same 2nd and 3rd gone but just get a JDM gs-r tranny with lsd for like idk a little over 1k </TD></TR></TABLE>
i agree
insidiouseg-6
Nov 11, 2008 08:30 PM
freddysEF
Jan 28, 2007 11:48 AM
seen4ever
Jan 1, 2005 08:49 AM
_jester_
Dec 27, 2003 04:26 AM
BLACKLUDE97
Nov 5, 2003 06:16 AM
