Need help with Apexi S-AFC ll ?
Old Nov 15, 2005 | 07:48 PM
decode22's Avatar
Default Need help with Apexi S-AFC ll ?
Whats up fellas, I want to know if is a good idea to install the apexi S-AFC ll on my car, This is what I have on my 98 civic ex (intake, cat-back exhaust, denso spark plugs) and also if anybody knows where I can find info on how to installed. THANKS
Old Nov 15, 2005 | 08:31 PM
T
Default Re: Need help with Apexi S-AFC ll ? (decode22)
No the SAFC would not be a good idea to put on your car, your basically bone stock. Build up the motor and then instead of the SAFC II get the Hondata S100, S200, or S300. Better system. Also dump the Denso's they are pieces of ***** just get NGK's.
Old Nov 15, 2005 | 08:51 PM
specv5150's Avatar
yeah the AFC would be a waste of money for you right now....ANY aftermarket fuel management would be wasteful until you have more done to your car.
Old Nov 15, 2005 | 10:19 PM
teknoracing's Avatar
Default Re: (specv5150)
Ditch the S-AFC and get an aftermarket header. You can keep the plugs, denso is pretty good. NGK is just the choice Honda uses. Use your money on other things.
Old Nov 16, 2005 | 06:50 AM
decode22's Avatar
Default Thanks guys .
Thanks for the help fellas.
Old Nov 16, 2005 | 06:51 AM
Kendall's Avatar
Fuel management is always a good idea, regardless of mods. Either way, I'd sell the SAFC and invest in a VAFC.
Old Nov 16, 2005 | 10:12 AM
specv5150's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Fuel management is always a good idea, regardless of mods. Either way, I'd sell the SAFC and invest in a VAFC.</TD></TR></TABLE>
Why get inferior fuel management when you can get a chipped ECU for less. Either way he doesnt even have all the minor bolt ons....I say its a waste . I gues you can buy it if you will have use for it down the road.
TranspeedMotorsports
Aug 26, 2006 01:04 AM
Dumped DB2
May 31, 2004 06:33 PM
ef93si
Dec 9, 2003 08:55 AM
fastcrxsi90
Feb 25, 2003 11:50 AM
