CV Joint Boot tear
Old Nov 15, 2005 | 04:48 PM
Elvis1977's Avatar
Default CV Joint Boot tear
I have a 98 accord 4-cyl. with 140k miles and original cv joints. I noticed a small tear in the passanger side boot and some grease has come out. Should I repair the boot or just replace the whole cv joint since it already has 140k miles?
Old Nov 15, 2005 | 05:04 PM
P_Adams's Avatar
Default Re: CV Joint Boot tear (Elvis1977)
If you have no noises associated with the CV Joint, it can be successfully resealed.
Just don't leave the building until you get it fixed.
P (I don't care if they ARE Blue Suede)
Old Nov 15, 2005 | 05:09 PM
jack1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elvis1977 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 98 accord 4-cyl. with 140k miles and original cv joints. I noticed a small tear in the passanger side boot and some grease has come out. Should I repair the boot or just replace the whole cv joint since it already has 140k miles?</TD></TR></TABLE>
Yeah, as someone who this past weekend replaced his axels, I would say that listen of a clicking noise when you turn while driving. If you don't hear anything, get a CV boot kit and get it sorted...
Old Nov 15, 2005 | 05:21 PM
Elvis1977's Avatar
Default Re: CV Joint Boot tear (P_Adams)
Yeah I understand what you guys are saying, BUT I have 140k miles. Should I just go ahead and replace the whole axle since something else might fail? The axle can't go forever! All comments appreciated.
Modified by Elvis1977 at 9:38 PM 11/15/2005
Old Nov 15, 2005 | 05:39 PM
Elvis1977's Avatar
Old Nov 15, 2005 | 05:53 PM
YeuEmMaiMai's Avatar
replace the joint.
Old Nov 15, 2005 | 06:54 PM
BLKFLSH's Avatar
Default Re: CV Joint Boot tear (YeuEmMaiMai)
That's what he wanted. Someone to tell him to change the cv joint.
Old Nov 15, 2005 | 07:30 PM
P_Adams's Avatar
Why? I've OE Joints that have never seen the light of day at 198,000m, 172,000m, and 147,000m; and an '88 that had its' 1st replaced at 214,000m.
With the logic being bantered about here, why not replace BOTH axles and the Ball Joints as well? And while you're at it, why not the inner control arm bushings and the springs?
P
Old Nov 15, 2005 | 07:41 PM
BLKFLSH's Avatar
Might as well do an engine swap too. Heck that engine has 140k miles on it, so it must be about to give out.
Old Nov 15, 2005 | 08:13 PM
with the boot being cracked it would just just as much to repair it as it would to replace the joint. I paid $95 to have my outer joint replaced it would have cost $90 for a boot replacement.
I dunno what the big deal is....but you are way out of line in your remarks.........
Old Nov 15, 2005 | 08:20 PM
BLKFLSH's Avatar
Do you have to take it all apart just to change the boot. I've never changed one myself. Seems like a boot would be cheaper than a cv joint. But I guess if your paying someone else to do it, and the labor is the same, what the heck.
Old Nov 15, 2005 | 08:21 PM
iam7head's Avatar
might as well get the whole thing, it's no so much of the part but if you doing the same amount of work, just replace the whole thing.
you will hate yourself later on if you starting to hear clicks after you put in your new boot
Old Nov 15, 2005 | 08:22 PM
BLKFLSH's Avatar
Default Re: CV Joint Boot tear (iam7head)
Old Nov 15, 2005 | 08:23 PM
Default Re: CV Joint Boot tear (BLKFLSH)
When I had it done they actually took the outer CV joint right off of the halfshaft and slid the new one on and reassembled the front suspension parts they loosened unbolted in the process.
Old Nov 16, 2005 | 07:15 AM
Elvis1977's Avatar
Well, I replaced only the boot since the honda repair man said not much grease leaked out. Man I hope the cv joint will last 200k+ The part and labor cost $160.
Old Nov 16, 2005 | 07:19 AM
213374U's Avatar
0x5359-0055
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elvis1977 &raquo;</TD></TR><TR><TD CLASS="quote">The part and labor cost $160.</TD></TR></TABLE>
I replace entire axles for $60
Old Nov 16, 2005 | 01:17 PM
promix's Avatar
I can tell that I still have original halfshafts on my 91 Honda. I already put 216k miles on it and had no problems. I purchased the car with 147k and Honda technician replaced the boots.
If no dirt or water gets into the CV joint - it is actually runs forever.
Whole halfshaft is around $66 - check http://www.thepartsbin.com.
Old Nov 16, 2005 | 09:31 PM
iam7head's Avatar
Default Re: CV Joint Boot tear (promix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by promix &raquo;</TD></TR><TR><TD CLASS="quote">I can tell that I still have original halfshafts on my 91 Honda. I already put 216k miles on it and had no problems. I purchased the car with 147k and Honda technician replaced the boots.
Whole halfshaft is around $66 - check http://www.thepartsbin.com.</TD></TR></TABLE>
the OEM one last alot long but most of the people would just buy the autozone one, which is around 30 bucks, free replacement of some sort of warranty.
the autozone axle are reconditioned.
Bad_dude
Jun 21, 2010 05:56 PM
ri3
Honda Civic (2006 - 2015)
Feb 13, 2009 11:46 PM
cubanteg16
May 8, 2008 10:44 PM
kb798
13
May 27, 2004 12:55 PM
JCracer723
10
Jan 22, 2004 02:54 PM
