Shaved door handels not allowed for dragracing
Shaved door handels not allowed for dragracing.Butt when you do this you have to fabricate something to open the doors.Butt to make a electric button isnt legal.Does somebody now something that can help my problem.Because i dont now what to do now.I hope somebody nows a trick for this problem.
sounds like you might have to find new doors.
the only other way around it is to pop in a lexan window whenever you want to race and have a handle that can be reached through a hole in the window. Ghetto, but I have seen it pass tech before.
I'd be looking for someone to trade doors with.
make a pull tab that hangs out of the door gap. when your not at the track, take it off. you just need a slot on the inside door jamb, with clearence to your old cam, it could be rod stock or aircraft cable, you may need to label it too, ie, "this end up" with a direction arrow - as long as you can demonstrate its functionality without interference from the electrical stuff, (like central locking) it should pass tech.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fabrak8rX »</TD></TR><TR><TD CLASS="quote">make a pull tab that hangs out of the door gap. when your not at the track, take it off. you just need a slot on the inside door jamb, with clearence to your old cam, it could be rod stock or aircraft cable, you may need to label it too, ie, "this end up" with a direction arrow - as long as you can demonstrate its functionality without interference from the electrical stuff, (like central locking) it should pass tech.
I was thinking the same thing as this and this what i am trying to do thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MI KENT »</TD></TR><TR><TD CLASS="quote">don't shave your doors off....problem fixxed</TD></TR></TABLE>
I thinkthi is the best answer!! Show cars aren't drag Cars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bumblezc »</TD></TR><TR><TD CLASS="quote">
I thinkthi is the best answer!! Show cars aren't drag Cars.</TD></TR></TABLE>
Who says you cant have the best of both worlds?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RHDelSol »</TD></TR><TR><TD CLASS="quote">Who says you cant have the best of both worlds?</TD></TR></TABLE>
IHRA, SCCA, about every other racing organization and me.
OneThirtyEight
Sep 23, 2001 03:51 PM
