what fuel filter micron size to run?
Old Nov 15, 2005 | 11:23 AM
redboost10's Avatar
Default what fuel filter micron size to run?
i posted this in the fi forum but no one seems to respond. i am wondering what size of micron fuel filter to run for a high hp fi civic? ill be running a weldon external fuel pump, sumped tank, all that stuff. -10 feed line
Old Nov 15, 2005 | 11:35 AM
Flamenco-T's Avatar
Default Re: what fuel filter micron size to run? (tgh99si)
-10 micron should be fine... I run them after the pump on all of our customers. This way if pump failed, the filter will catch all debris (if any) before it goes to the engine.
Old Nov 15, 2005 | 12:12 PM
tony1's Avatar
Default Re: what fuel filter micron size to run? (Flamenco-T)
You really should run a 100 micron filter before the pump to pickup crap from the tank before it gets to the pump.
Old Nov 15, 2005 | 12:14 PM
Flamenco-T's Avatar
Default Re: what fuel filter micron size to run? (tony1)
Tony,
pump is cheaper than motor aha
bets way to do it is to have 2 filters, one before and one after. With the Bosch setup that I have I have a filter inside the tank before the pump. Good ol 40 micron
Old Nov 15, 2005 | 12:20 PM
Turbo-charged's Avatar
just connect like 64 filters together so you have one big beefy solid filtered fuel line.
Old Nov 15, 2005 | 02:22 PM
redboost10's Avatar
Default Re: what fuel filter micron size to run? (Turbo-charged)
thanks guys. that helps out a bunch except for the 64 filter thing. haha
Old Nov 15, 2005 | 07:55 PM
redboost10's Avatar
one more question, are you guys connecting the filter right to the exit side of the pump, or do you run some ss line between the two?
Old Nov 16, 2005 | 08:33 AM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">one more question, are you guys connecting the filter right to the exit side of the pump, or do you run some ss line between the two?</TD></TR></TABLE>
Just connect it right at the exit, therefore you won't have to buy additional lines and hose ends..
stan
Old Nov 16, 2005 | 10:59 AM
redboost10's Avatar
sounds good. thank you stan. i appreciate the help
ZXiPoZ
Jun 10, 2012 05:43 AM
BOOSTWERKS
Mid-Atlantic (Sales)
Jan 5, 2009 06:08 AM
aleks77
May 10, 2007 08:36 PM
98AccordEX
Jan 9, 2004 04:08 AM
