lower control arm civic type R and integra type R
hi,
who have a pictures of the front lower control arm :
Civic Type R EK9
Integra Type R 98 spec JDM
Integra Type R 99-01 spec JDM
Integra Type R USDM
or, which has lower control arms in tole folded: Civic or Integra ?
thanks
Modified by hondastreet at 9:51 PM 11/15/2005
Civic Type R EK9
Integra Type R USDM
thanks
sorry tole folded : Flanged Sheet of steel
Modified by hondastreet at 4:19 PM 11/16/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondastreet »</TD></TR><TR><TD CLASS="quote">which has lower control arms in tole folded: Civic or Integra ?</TD></TR></TABLE>
i'm just curious if anyone has any ****** clue what this guy is asking........
WTF mate?!?!?!
tole folded..... I hope this guy answers back cause now I'm really curious what he meant.
Also I can't understand why he wants pics of the front LCA's. I'm pretty sure all the ITR front LCA's are the same, but the CTR one is different
Yes The LCA's different for the CTR if you compare with ITR 98 JDM spec, or ITR 96 JDM spec, or 99 JDM Spec, or USDM 99-01 spec.
I want to know, who have this control arms
http://hybrid2.honda-perf.org/...a.jpg
I'm french, sorry for my grammar
If i look on this Internet site
http://www.tokyo-express.co.uk...p.htm
I see the lower control arm for the civic type R EK9
The LCA for Civic TYPE R are in sheet of steel : flanged sheet
the ITR LCA are steel, structure of steel
My question was which one have LCA in sheet of steel, and the answer is CIVIC type R
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D »</TD></TR><TR><TD CLASS="quote">
i'm just curious if anyone has any ****** clue what this guy is asking........</TD></TR></TABLE>
You don't know what Tole Folding is?
dumbass
dumbass
I ask this question because i buy 5 lug Type R conversion and i don't know if i need to use 32mm or 36mm axle.
I know that the conversion kit have a LCA flanged sheet of steel
so, if i have the LCA with flanged sheet, it's CIVIC type R and i need to use 32mm axles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondastreet »</TD></TR><TR><TD CLASS="quote">I ask this question because i buy 5 lug Type R conversion and i don't know if i need to use 32mm or 36mm axle.
so, if i have the LCA with flanged sheet, it's CIVIC type R and i need to use 32mm axles </TD></TR></TABLE>
uhmmm you could measure it?
And your question actually relates to the hub then I'm assuming since you are wondering about the axles..
99-00 Civic Si's Have stamped sheet metal control arms in the front. These control arms have mounts for a sway bar and are stronger than the cast steel versions found on the lower models. I believe that is what he is talking about.
http://www.hondaautomotivepart...82%29
Scott, who'd be interested in taking the easy way out if there were one...
Jimmy
12
Aug 23, 2017 11:51 PM
rasta420
Jul 27, 2002 12:30 AM
