Does the Remote wire have constant power?
Old Nov 15, 2005 | 07:10 AM
92ehatch's Avatar
Default Does the Remote wire have constant power?
is the remote wire a constant power supply or does it only act as a switch, it powers up to switch the devices on then no power runs through it?
im running mine next to my RCA at the moment (havent got my new amp cause mine blew) and i just wanted to know, cause if its a constant power supply im gonna move it over next to my power cable.
TIA
Old Nov 15, 2005 | 07:21 AM
tequilakid's Avatar
Default Re: Does the Remote wire have constant power? (93egsedan)
The remote wire has a constant signal going through it when the head unit is on.
Old Nov 15, 2005 | 07:37 AM
MLD211's Avatar
Your remote wire is a remote turn on wire the wire acts as a switch in the sense the when you HU is one the remote wire out puts 12V turning on you amps or whatever. The remote wire does have power running through it the entire time the HU is on. However, the amount of power running throug it is very little. You will have no problem with inducted noise by running your remote wire with your RCA's. I always run the remote wire with the RCA's its much easier that way.
Old Nov 15, 2005 | 08:12 AM
92ehatch's Avatar
Default Re: (MLD211)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLD211 &raquo;</TD></TR><TR><TD CLASS="quote">Your remote wire is a remote turn on wire the wire acts as a switch in the sense the when you HU is one the remote wire out puts 12V turning on you amps or whatever. The remote wire does have power running through it the entire time the HU is on. However, the amount of power running throug it is very little. You will have no problem with inducted noise by running your remote wire with your RCA's. I always run the remote wire with the RCA's its much easier that way.</TD></TR></TABLE>
sweet thanks, now i dont have to tear out the center part where my shifter is again. just to fix it
Old Nov 15, 2005 | 08:34 AM
ITB
Guest
Posts: n/a
i think it should be ok, I ran my red wire on the left, and my remote and RCA on the right
Old Nov 16, 2005 | 03:14 PM
Odessa's Avatar
Default Re: (ITB)
Some rca cables even come with a remote wire. Shouldn't be a problem.
rick_rabies
Sep 10, 2009 06:59 AM
hondalove323
Honda Civic (2001 - 2005)
16
Jul 16, 2008 12:01 AM
cd5_2NR
Audio / Security / Video
Apr 20, 2003 09:47 PM
-1TSXer-
Jan 26, 2003 09:28 PM
PearlWhiteAccord
Jun 18, 2002 05:17 AM
