FS N/A H-Series
Old Nov 14, 2005 | 09:02 PM
WTR's Avatar
WTR
Default FS N/A H-Series Swap
H22A1 Darton MID Sleeves installed by ERL
Crank has been lightened and balanced
Pro Drive oil pump
Crower Pro Billet Rods
Endyn Rollerwave Pistons
H22 head with Endyn Full Race port job including the quinch area being weld for more comp
The head has Endyn Valves, Skunk 2 Valve Springs and Retainers, Also Skunk 2 cams
Skunk2 intake manifold that has also been modified by Endyn with 70mm throttle body
Skunk 2 cam gears,Greddy Timing Belt,An-r header,RC 440 injectors
H22 transmission with Pro Drive Spool also H23 trans
Hasport motor mounts for EG
Stock axles to do swap in eg
This motor went 11.80's in a 2150lbs car
I willing to let this go for $7500 will also consider trades
i have way more than this in the setup
i also i have a Autronic Ecu $1200
Old Nov 14, 2005 | 09:09 PM
soslodelsol's Avatar
Default Re: FS N/A H-Series Swap (WTR)
wow pretty pricey...but then again however fast you want to go depends on how deep your pockets are.
Old Nov 15, 2005 | 08:29 AM
WTR's Avatar
WTR
Default Re: FS N/A H-Series Swap (soslodelsol)
bump
Old Nov 16, 2005 | 09:02 PM
WTR's Avatar
WTR
bump for a N/A H motor
BOOSTWERKS
Mid-Atlantic (Sales)
Sep 29, 2010 05:55 AM
BOOSTWERKS
Jun 16, 2010 04:04 PM
KB91Hatch
Dec 16, 2009 08:31 PM
WTR
Jun 3, 2006 03:02 PM
