to those of you with AEM intakes...
Old Mar 11, 2002 | 11:41 AM
GS-R_nut's Avatar
Default to those of you with AEM intakes...
hey I have a 99 integra GSR.. w/ Apex Dunk 115 catback system...I just got a AEM CAI w/ a bypass valve.. I really hate the fact that I have to cut the pipe..what is the chance that water will be sucked up?? isnt it well protected from all the factory splash gaurds?? I have read everything on the net and I really need some good hard facts.. it is my daily driver also...
thanks!
Old Mar 11, 2002 | 11:47 AM
SonicGSR's Avatar
Default Re: to those of you with AEM intakes... (GS-R_nut)
Dont use the bypass,I thought those things had a recall on them?
Old Mar 11, 2002 | 11:50 AM
5-SpeedFreak's Avatar
New User
Default Re: to those of you with AEM intakes... (SonicGSR)
No recall on the bypass. I have it on my car and have no problems with it. I think problems are due to installation error.
If you want a little piece of mind install it. Cutting the pipe is not brain surgery.
Old Mar 11, 2002 | 12:10 PM
itr0045's Avatar
Default Re: to those of you with AEM intakes... (5-SpeedFreak)
The bypass valve is a waste of money and time. Don't use it. My car gets driven in monsoons everyday of the year to work, and I have never had problems with it. I have ran an AEM on two cars now. All my friends run AEM's and never have had any problems. You'll be fine.
Old Mar 11, 2002 | 12:12 PM
EL Vap133's Avatar
It only works if your filter is fully submerged in water.
Old Mar 11, 2002 | 12:27 PM
Cone's Avatar
AEM did recall the first batch of bypass valves because a piece of it could break off and get sucked into the engine, but the problem was fixed a long time ago. Just keep your eye out for deep puddles and you should be ok. I heard you lose like 2-3whp from it because the aluminium is cut and can't conduct heat all the way through the tube. So the top half becomes warm, and the bottom half stays cold.
-Andrew
Old Mar 11, 2002 | 12:35 PM
LS_racer's Avatar
Here's the story on the AEM recall or at least the AEM story on the recall for the bypasses. http://aempower.com/voluntary.htm
Old Mar 11, 2002 | 12:43 PM
Legacy_CPA's Avatar
I bought the bypass valve, but after reading that it drains power and that it is almost impossible to hydrolock unless your car is submerged in water, I tossed it in the garage. I've driven in several stormy days and nothing has happened. But, I also live in Southern California where it hardly rains.
Old Mar 11, 2002 | 12:46 PM
owen_the_soyboy's Avatar
Default Re: to those of you with AEM intakes... (Vap133)
exactly. when are you going to submerge your entire front bumper in water?
never. I hope!
dotn do it... just say no to the bypass valve!
dohc_profile
Oct 11, 2007 04:48 PM
prelude93si
Aug 18, 2003 01:15 PM
BranzLS
Mar 21, 2002 08:52 AM
01-1293
Mar 20, 2002 08:25 AM
hobo79
Aug 24, 2001 09:17 PM
