CAR IS DOWN!!! PLEASE HELP
Old Nov 14, 2005 | 08:12 PM
RSX_TypE-1's Avatar
Default CAR IS DOWN!!! PLEASE HELP
ok so i was driving shifting around 4 grand and all of a sudden i hear a grinding noise and my rpm's slowly fall back to zero and my car won't start back up, im assuming its my clutch and it finally gave out because of the smell after it happened, does anyone know what i need to get fixed?
Old Nov 15, 2005 | 09:12 AM
EP3tune2RULE's Avatar
Default Re: CAR IS DOWN!!! PLEASE HELP (RSX_TypE-1)
how many miles you have on the car?..
Modified by EP3tune2RULE at 11:36 AM 11/15/2005
Old Nov 15, 2005 | 10:25 AM
RSX_TypE-1's Avatar
Default Re: CAR IS DOWN!!! PLEASE HELP (EP3tune2RULE)
around 40k, another thing when the incident happened my rpm's wouldn't go up as i pressed on the gas as the rpm's fell all the way to zero
Old Nov 15, 2005 | 05:21 PM
ebp_dc2's Avatar
similar thing happend to me in my integra one time. turns out it was loose wires on the dizzy
all im saying is check all your wires
Old Nov 15, 2005 | 07:51 PM
RSX_TypE-1's Avatar
that could be a possibility, theres just so many options right now, but im just trying to pinpoint the problem, thx for the information
Old Nov 15, 2005 | 08:49 PM
Default Re: (RSX_TypE-1)
Do you have aftermarket intake?
Old Nov 16, 2005 | 11:06 AM
RSX_TypE-1's Avatar
Default Re: (EP3tune2RULE)
yes i do have an aftermarket intake AEM v2, ive gotten feedback as to what the problem might be and wires might be the case, i was also thinking maybe spark plugs or even alternator, does this sound right?
Old Nov 16, 2005 | 04:35 PM
pon55's Avatar
when asking questions give all info available.
will it turn over (When you turn the key to start does anything happen?)
These problems are approached as a flow chart. what works-what dont!
Old Nov 16, 2005 | 07:10 PM
RSX_TypE-1's Avatar
Default Re: (pon55)
ok, when the key is turned everything sounds normal, but it doesn't turn over it just keeps trying to, all the lights, alarm, stereo etc... are in perfect working order, the car just won't start
Old Nov 16, 2005 | 09:59 PM
RSX_TypE-1's Avatar
ok update, i just tried to jump my car with some cables in hopes that the alternator just needed a little jolt to help it turnover, but that didn't work
Old Nov 16, 2005 | 10:44 PM
whiteDCfiver's Avatar
Not tryin to be a smart *** or anything, but you have gas in the car? Maybe you dont and your fule gauge is actin up.
Old Nov 17, 2005 | 06:18 AM
Default Re: (Captin Bodussy)
When did you install the AEM V2? because it could be the case that it's loosened..
check here
It happend to a few of my friends, one was an EVO and the other one was S2000..
We run into the similar signs that you mentioned...Hope it helps...wish I could help you more but I'm not a mechanic..
Old Nov 17, 2005 | 07:42 PM
RSX_TypE-1's Avatar
thanks to everyone for the advice, it happend to be the wire that was hooked up to the crankshaft, wasn't connected fully so all we needed to do was plug and play...thanks again
Old Nov 18, 2005 | 04:20 PM
glw's Avatar
glw
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RSX_TypE-1 &raquo;</TD></TR><TR><TD CLASS="quote">thanks to everyone for the advice, it happend to be the wire that was hooked up to the crankshaft, wasn't connected fully so all we needed to do was plug and play...thanks again </TD></TR></TABLE>ha, ha... there are no wires on the crankshaft!
nastyek9
Jul 9, 2005 09:55 AM
chictunner97ex
Nov 18, 2004 01:27 PM
Geiro94rs
Nov 11, 2004 11:01 AM
just4747
Sep 18, 2004 08:23 PM
betsuni
Oct 15, 2001 08:16 PM
