what is limp mode?
Old Nov 14, 2005 | 08:12 PM
ev13lf's Avatar
Default what is limp mode?
i've been having a problem with my b16 92 cx for about three months now, ever since i did the swap. i think it's in limp mode, but i haven't been able to figure that out. I don't get any cel, but the rev limiter kicks in at 7000 rpm. Ive heard that limp mode will change the rev limit to 7000, but i believe the ecu throws a code when the car is in limp mode. i'm running a jdm 93 b16a2 with a p28, all out of the same front clip. any suggestions?
Old Nov 14, 2005 | 08:15 PM
o5mar1's Avatar
Default Re: what is limp mode? (ev13lf)
no limp mode prevents you from reving pass 3k rpm and if you have an automatic it keep you can only use 3rd gear and reverse. but if its stick you just cant rev past 3k. what ecu are you using?
Old Nov 14, 2005 | 08:18 PM
ev13lf's Avatar
Default Re: what is limp mode? (o5mar1)
p28, out of the same car the b16 came from. i thought it was the cluster for a while, but i drove in a friends b16 crx with a stock cluster and it pulled right to the 78 redline according to the tach. i really like to retain a stock appearing car, so i don't really want to put in an aftermarket tach.
Old Nov 14, 2005 | 08:26 PM
ev13lf's Avatar
i thought this could possibly be caused by a bad distributor, anybody had a problem like this?
Old Nov 14, 2005 | 08:38 PM
ev13lf's Avatar
bump
come on guys
i've seen similar problems in the archives, and it looks like those guys didn't get any answers
Old Nov 14, 2005 | 08:42 PM
T
Im just thinking that possibly cuz I know that P28's are a SOHC VTEC ECU that it still thinks its a SOHC and those cannot rev over that. Is it chipped??? IF it has not been reprogrammed to DOHC mode it will not go past that point. You more than likely need to get it chipped and tuned. Thats just my 2 cents.
Old Nov 14, 2005 | 08:43 PM
o5mar1's Avatar
i agree
Old Nov 14, 2005 | 08:44 PM
T
I just looked and i confirmed it the second gen B16's run a P30 ECU. SO what you need to do is get the P28 chipped and tuned. Don't dump it those are great ECU's. Just like i said get it chipped and tuned. Hondata is the way to go.
Old Nov 14, 2005 | 08:45 PM
o5mar1's Avatar
get like the s100 or s200 there under 300 bucks and if you plan on building the b16 or boosting it will help you in the long run
Old Nov 14, 2005 | 08:49 PM
ev13lf's Avatar
Default Re: (o5mar1)
actually, i am running a p30.
sorry about that, i kind of feel like a jerk for that one
but that just makes my problem stranger
Old Nov 14, 2005 | 08:53 PM
E.Honda's Avatar
Drop 2 viagra in the oil cap.
Old Nov 14, 2005 | 08:54 PM
T
Default Re: (E.Honda)
do you hit vtec at the xover point??? Or no VTEC????
Old Nov 14, 2005 | 09:00 PM
ev13lf's Avatar
Default Re: (ev13lf)
come on guys, i gotta figure this out
the car drives normal up to 7k and then it hits a rev limiter. there's no cel.
anybody out there running stock gauge clusters? maybe my gauge cluster is reading wrong. my vtec comes on just above 5k though, i think the stock crossover is supposed to be at 5300, so this seems right in line with what should be happening
and then it cuts off at 7k
any suggestions/ personal experience?
Old Nov 14, 2005 | 09:05 PM
You_Get_Vapors
Guest
Posts: n/a
Default Re: (H22JDMEG)
If your ECU is running in limp mode you will not be able to accelerate the car past 5000 rpms, and you will most likely be throwing a code. That is how a stock OBDII ECU works, as for a chipped or non-chipped or JDM ECU works, I do not know.
Old Nov 14, 2005 | 09:06 PM
T
this has nothing to do with the stock gauge closter. I am running the stock gauge cluster on A h22 hatchie and i go all the way to 7500 and the gauge cluster limit is up to 7000. My friend is running a B16 integra which redlines also at around 7000 and he goes up to 8000. I believe this could and most likely is an ECU programming setup issue. Have you searched????
Old Nov 14, 2005 | 09:10 PM
ev13lf's Avatar
i've searched, and ive heard people reference cars being limited to 7k, but everything that i have seen in the archives have attributed this to the car being in limp mode. as i recall it was on obd0 cars in the crx forum. this is an obd1 setup with a stock ecu. i looked inside the ecu adn its virgin.
Old Nov 14, 2005 | 09:13 PM
ev13lf's Avatar
i have heard some people say that this could be caused by a bad distributor, but im not certain of this and that doesn't really seem possible if the car runs fine up to 7k.
i don't know what to do about this, and its driving me nuts
Old Nov 14, 2005 | 09:32 PM
vltnolia's Avatar
Limp in mode, is when the computer engine management system in which one or more major component circuits have falied and a substitute value is used to retain driveabilty. Until you fix the problem.
Old Nov 14, 2005 | 10:01 PM
filipinoRebel_blueEG's Avatar
Default Re: (vltnolia)
im sorry but i jus scanned thru this topic nd first off.. jdm b16a2 ??? dont think so. and vtec doesnt 'xover' vtec is timing.
Old Nov 14, 2005 | 10:05 PM
SOHC4life 96's Avatar
Default Re: (filipinoRebel_blueEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filipinoRebel_blueEG &raquo;</TD></TR><TR><TD CLASS="quote">im sorry but i jus scanned thru this topic nd first off.. jdm b16a2 ??? dont think so. and vtec doesnt 'xover' vtec is timing.</TD></TR></TABLE>
No it's not. VTEC has nothing to do with timing. It's speed, oil pressure, and water temperature. Good try though.
Old Nov 15, 2005 | 05:52 AM
Slamaccord's Avatar
Default Re: (SOHC4life 96)
are you sure its a p30 b/c if your running a p28 i believe the redline on them is 7200 rpms
Old Nov 15, 2005 | 06:45 AM
Braco11's Avatar
Default Re: (Slamaccord)
have u tried using another ecu?
Old Nov 15, 2005 | 10:48 AM
blkhatch92's Avatar
are you even 100% sure theres a b16 in that cx? lol
Old Nov 15, 2005 | 11:16 AM
EG6_GUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22JDMEG &raquo;</TD></TR><TR><TD CLASS="quote">this has nothing to do with the stock gauge closter.</TD></TR></TABLE>
Actually, it might. I had an sir2 motor put in my 93si and the factory guage cluster was off. It looked like my rev limiter was set at 7200rpm. I hooked up a VAFC and my limiter was right where it was supposed to be. I then replaced my meter panel with an sir2 one and this one displays fine.
Not saying that the factory one won't work, but before the swap it has never had to go up that high.
Old Nov 15, 2005 | 03:08 PM
Default Re: (EG6_GUY)
vtec has nothing to do with timing?! wtf. variable valve TIMING ****** idiot
