2002 Accord SE Foglight search
Old Nov 14, 2005 | 04:50 PM
PITFU's Avatar
Default 2002 Accord SE Foglight search
Anyone got a suggestion for aftermarket foglights for an 02 Accord coupe? It has those little grille corner squares on the outside, and then the open slit grill across the bottom... I don't think my headlights give me the view/coverage I really want...
Old Nov 14, 2005 | 05:05 PM
talontsiawd's Avatar
Default Re: 2002 Accord SE Foglight search (PITFU)
Oem ones will look the cleanest but will be more expensive than some other's around. But they will have a stock switch and fit the bezzel right.
Old Nov 14, 2005 | 05:14 PM
Ross 2.0's Avatar
In a Junkyard near you.
Actually the best and cheapest way would be to change your headlight bulbs. I have Sylvania Silverstar (D.O.T approved) bulbs and they work great. Definately improved lighting. The light shines as far as i can see on high beam and low beam gives excellent side to side lighting.
But finding legal aftermarket lights is difficult. If you actually find a set that is legal your probably going to spend close to what you would pay for Honda lights.
Old Nov 14, 2005 | 05:22 PM
Default Re: (MooGoCow3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">Actually the best and cheapest way would be to change your headlight bulbs. I have Sylvania Silverstar (D.O.T approved) bulbs and they work great. Definately improved lighting. </TD></TR></TABLE>
Yep, another good investment. I was skeptical at first when i bought these but i find i rarely use the high beams now. They aren't amazing but far better than stock. People compare them to HID's, they arn't that good but for $40 for the low beams, well worth it.
Modified by talontsiawd at 5:34 AM 11/15/2005
Old Nov 14, 2005 | 05:54 PM
PITFU's Avatar
I'm thinking thats what I just put on there. I need to adjust my drivers side light tho... the beam seems to be pointed high and to the right... so I"m losing coverage on the lower side.
nicolaselias
Feb 10, 2008 07:31 PM
jneusch
Jan 30, 2008 06:22 AM
Patman
Jan 5, 2007 01:47 PM
JongChan12
Dec 9, 2002 12:30 AM
Starrman85
Dec 7, 2002 10:19 PM
