IGN TIMING 88 ACCORD
Old Nov 14, 2005 | 02:23 PM
JWEITEN's Avatar
Default IGN TIMING 88 ACCORD
I HOPE I CAN GET SOME HELP. I OWN A 1988 ACCORD WITH 230,000 KMS
(138,000 MILES) ON IT, WITH A CARB, A.T. AND I CANNOT LOCATE THE
SPECS FOR IGN TIMING. (MUST HAVE BEEN REPAINTED AND STICKER UNDER
HOOD MISSING)
THANKS
Old Nov 14, 2005 | 02:57 PM
Chiovnidca's Avatar
Default Re: IGN TIMING 88 ACCORD (JWEITEN)
Should be set to the red mark.
Old Nov 14, 2005 | 03:25 PM
HondaMike17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JWEITEN &raquo;</TD></TR><TR><TD CLASS="quote">WITH A CARB,
old school
Old Nov 14, 2005 | 03:40 PM
deserthonda's Avatar
it is 15 degr BTDC . like Chio said the RED mark
Old Nov 17, 2005 | 12:22 PM
JWEITEN's Avatar
Default Re: IGN TIMING 88 ACCORD (Chiovnidca)
THANKS FOR THE INFO ON THE TIMING...HARD TO GET INFO ON THIS OLD GIRL!
Old Nov 18, 2005 | 11:44 AM
sauceja's Avatar
I have a 89 accord and with timing set at tdc is correct at both marks. Yet when idling I get a horrible shaking that goes away at about 1800 rpms. I just replaced the head and have low but good compression. Around 140 to 150 depending on cylinder.
Spark is good. Valve adjustment is about to be done right now. How do I know if a valve is bent other than taking it out????
I can hear popping sounds coming from #4 cylinder if I touch gas at just the right time on idle. Does not happen always but sometimes and I think the valve might be hitting the piston.
Any help would be appreciated.
Old Nov 18, 2005 | 11:48 AM
sauceja's Avatar
Oh yeah and with timing light the BTDC does look like around 4 degrees like manual states. Would I need to advance or retard this to adjust??? I just put a 5 sp tranny on it and the flywheel is on right so I know the marks and timing is correct as I have checked after running.
laloquera916
Jul 27, 2016 09:29 PM
jmissiaen
May 13, 2009 06:01 PM
DIY_Racing
Jul 22, 2004 11:20 AM
