Hondata s200 Box
I have a hondata s200 box i do not need. Brand new asking $350 Has boost and g Sensor options
The base price for the s200 is $295 This allows the ECU to be tuned by a dealer or anyone with ROM Editor V3 and a programmer. You will need a base program (ROM) for your vehicle/engine/ECU which you can get from your dealer.
Price Description
$295 Base s200 system - Datalogging, 3- step rev limiter, speed limiter removed (if applicable), tunable fuel and ignition tables, expanded rpm fuel & ignition tables, VTEC control, adjustable rev limiter.
Various additional options are available, either when the unit is ordered or as an upgrade later:
Price Description
$50 3 step rev limiter- Launch control and full throttle shift. (optional upgrade on systems purchased before 3/1/05)
$200 Boost capability. Needed for turbo or supercharged applications
$50 Datalogging capability. Required if you want to tune it yourself (optional upgrade on systems purchased before 12/13/04)
Discontinued G Sensor module.
$200 ROM Editor V3 (requires datalogging). Required for tuning yourself.
$180 Romulator realtime emulator.
$180 Programmer (requires ROM Editor V3) Required for tuning yourself.
Price Description
Price Description
