Steering pulls right, left on small bumps
Here is the list
No PS
Caster at 0
Camber front -3deg
rear -2
1/16 toe out front
0 rear toe
I had the caster at +1 but it made it real hard to turn in a slalom. I would literally have to hang on the steering wheel to get it to turn. Took caster out to 0deg and it turns pretty normal.
I can't say if this problem was there before the caster was changed.
Now, every little bump the steering wheel pulls left and right, I am always fighting to keep the steering straight. Most times on the turns I can't get my hand over to the other to steer, the wheel keeps jumping left ot right.
Any ideas or questions or suggestions.
I want to say give it +.5deg caster to see what happens but that is the only place I can think to start besides reinstalling the Power steering.
thanks
No PS
Caster at 0
Camber front -3deg
rear -2
1/16 toe out front
0 rear toe
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Renegade »</TD></TR><TR><TD CLASS="quote">How will the engine mounts do that?</TD></TR></TABLE>
Engine movement will result in some movement of the axles which can result in some movement of the hub, even if there is no steering input.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Renegade »</TD></TR><TR><TD CLASS="quote">I am planning to run 0 toe next event. </TD></TR></TABLE>
Actually 1/16 is good for the track, just not the streets (where I get pulling and darting). I bring my plates to the track so I can set it before and after the event.
I do the same I set toe and camber at every autocross event. I run -2 and 0 toe on the street. I've noticed that it tracks out easily with bumps, but not as much. I did notice yesterday that when I hit a bump when the car lifts is when the wheels turn to eithe side, maybe it is an effect fo the camber as well. Not big enough contact patch specially when the car jumps on a bump the weight is lifted.
krazy one
Suspension & Brakes
19
Mar 8, 2017 04:06 AM
euG3dc2r
Apr 18, 2005 05:02 AM
