Where can i put the Ultra MDI system?
Old Nov 13, 2005 | 11:13 PM
Edward's Avatar
Default Where can i put the Ultra MDI system?
I just bought the Ultra MDI system. Don't know where can i mount them. Does anyone can share your pic with mounting the MDI system? Thanks a lot!!
Modified by Edward at 9:55 AM 11/14/2005
Old Nov 14, 2005 | 03:57 AM
Edward's Avatar
Default Re: Where can i put the Ultra MDI system? (Edward)
Anyone?
Old Nov 14, 2005 | 04:17 AM
citrus3000psi's Avatar
ive seen pictures of the layout recently around here..Give a search and you can find one. But just a shot, if you don't have ABS put them there, if you battery is relocated put them there, or look for some room on the firewall.
Old Nov 14, 2005 | 04:40 AM
Kengs's Avatar
Default Re: (citrus3000psi)
This is the only photo I have saved in my computer:
Old Nov 14, 2005 | 05:17 AM
Dr Pooface's Avatar
Default Re: (Kengs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kengs &raquo;</TD></TR><TR><TD CLASS="quote">This is the only photo I have saved in my computer:</TD></TR></TABLE>
Looks like your M's Super Cleaner is going to eat your overflow.
Old Nov 14, 2005 | 05:25 AM
Kengs's Avatar
Default Re: (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">
Looks like your M's Super Cleaner is going to eat your overflow. </TD></TR></TABLE>
I should've noted that is NOT my car
Old Nov 14, 2005 | 08:03 AM
white rocket's Avatar
I would really love to hear a review of this product. Any chance of that?
As for mounting, I'd get a Hawker(or similar small battery) and mount it above it on the firewall.
Old Nov 14, 2005 | 09:09 PM
Edward's Avatar
Any other mounting method? Any pics?
Old Nov 14, 2005 | 09:51 PM
Haleiwa-Brando's Avatar
It seems almost like a moot point installing it. Considering the obvious fact that the engine would have to suck HOT air AROUND a container holding HOT liquid.
Old Nov 15, 2005 | 05:04 AM
Edward's Avatar
I want to find a better place to mount the coil. Anyone know? After i install it, I will do a dyno test.
Old Nov 15, 2005 | 10:45 AM
Jowee's Avatar
Default Re: Where can i put the Ultra MDI system? (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">It seems almost like a moot point installing it. Considering the obvious fact that the engine would have to suck HOT air AROUND a container holding HOT liquid.</TD></TR></TABLE>
Last time I checked, the overflow reservoir doesn't get that hot......
Old Nov 15, 2005 | 01:07 PM
garylythgoe's Avatar
Default Re: Where can i put the Ultra MDI system? (Jowee 1162)
Is that M's Air Cleaner made by a company called M's? (stupid Q maybe?)
Is it still available, ive never seen anything like that?
Old Nov 15, 2005 | 01:48 PM
Kengs's Avatar
Default Re: Where can i put the Ultra MDI system? (garylythgoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garylythgoe &raquo;</TD></TR><TR><TD CLASS="quote">Is that M's Air Cleaner made by a company called M's? (stupid Q maybe?)
Is it still available, ive never seen anything like that?</TD></TR></TABLE>
M's is actually made by Gruppe M. As far as i know, the intake is still sold in Japan, cost is somewhere around 650-680 bux
Old Nov 15, 2005 | 03:34 PM
Black R's Avatar
25 Year Member
.....this thread is about the ultra mdi, so let's try to stay on topic.
I will say though, that I dyno'd several intakes in a test and the M's was the top performer.
Old Nov 15, 2005 | 08:16 PM
uNF$@#!'s Avatar
Default Re: Where can i put the Ultra MDI system? (Black R)
mostly, the overflow reserve tank doesnt have "hot" liquid...room temp yes.
i'd be more concerned about sucking hot air around the rad .
Old Nov 16, 2005 | 02:12 AM
Edward's Avatar
Anyone got pics? Thousand thanks !
Old Nov 24, 2005 | 10:50 PM
Takashi1978's Avatar
I just saw a guy dyno with the MDI that he just brought from Jpn yesterday and the results was very dissapointing.
His engine spec was
B16B
Toda-C + valvetrain
Toda Piston
Spoon ECU
He just went for 3 dyno runs to test out the system and no tuning.
To his suprise it only gained 0.8hp peak BUT at the same time he also LOST an average 10-15hp from 3000rpm until vtec x-over.
After vtec x-over it was +/- 1-2hp.
Maybe the results will be diff should he had any kind of standalone ecu?
After he pluged in the Ultra MDI sys it did make his a/f go quite lean.
Old Nov 24, 2005 | 11:15 PM
Reid's Avatar
Global Moderator
Default Re: Where can i put the Ultra MDI system? (Takashi1978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takashi1978 &raquo;</TD></TR><TR><TD CLASS="quote">I just saw a guy dyno with the MDI that he just brought from Jpn yesterday and the results was very dissapointing.
His engine spec was
B16B
Toda-C + valvetrain
Toda Piston
Spoon ECU
After he pluged in the Ultra MDI sys it did make his a/f go quite lean.</TD></TR></TABLE>
So he lost 10-15 hp in the midrange with ONLY the installation of the MDI?
His setup is far from optimal to begin with.
Old Nov 24, 2005 | 11:21 PM
raffiT78's Avatar
sorry for the stupid Q? but what is an MDI?
Old Nov 25, 2005 | 02:04 AM
Edward's Avatar
Default Re: Where can i put the Ultra MDI system? (Reid)
I didn't do a dyno test yet. But i tried 0-100 km/hr. 3 times without MDI and 3 times with MDI. The average time without MDI is 6.85s and the average time with MDI is 6.18s. I am not sure it is worth or not. But i am quite happy with MDI. My car is totaly stock(except the mugen twin loop). I will put the JDM 4-1 and do a dyno test next month. So, i will post to here again next month.
Old Nov 25, 2005 | 08:51 AM
Any pics of it installed?
Old Nov 25, 2005 | 11:20 AM
B2FiNiTY's Avatar
Default Re: Where can i put the Ultra MDI system? (white rocket)
Look above
Old Nov 25, 2005 | 11:38 AM
Default Re: Where can i put the Ultra MDI system? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Look above </TD></TR></TABLE>
I saw that . I was wondering where "HE" installed it. Since this thread was all about that.
Old Nov 28, 2005 | 07:57 AM
Edward's Avatar
Here is the pics:
Old Nov 28, 2005 | 12:08 PM
Kengs's Avatar
I still gotta get me another one of those; this time I'll keep it too
