b16 to an ls swap
No wiring needed. Just swap engines and thats it. The only thing is, that if you have a stock b16 header, it will not clear the oil pan on the ls. I just did the swap and that was my only problem.
The ls with the b16 tranny felt a lot quicker than the straight b16. As for the downpipe just try it, it might be a ls or gsr on there. You can't use the intake manifold off the b16. But if you have a ls one, it will be the same placement.
