plx m-300 says lean when off the gas
Old Nov 13, 2005 | 07:34 PM
confidence's Avatar
Default plx m-300 says lean when off the gas
i was wondering if this is honda thing before i ask plx about it.
everytime i take my foot off the gas the gauge says "lean air." it starts reading again after a few seconds but i never get any real numbers of how lean it is. anyone else using the plx300 or other wbo2 getting this kind of reading?
Old Nov 13, 2005 | 08:28 PM
Relic1's Avatar
it's normal.
when you're slowing down in gear with your foot off the gas, honda ECUs turn off the injectors, which causes LEAN or AIR to be displayed.
Old Nov 14, 2005 | 02:56 AM
an2ny888's Avatar
Default Re: plx m-300 says lean when off the gas (snail)
it's normal, injectors shut off upon decceleration
Old Nov 14, 2005 | 03:42 AM
Black R's Avatar
25 Year Member
Default Re: (Relic1)
.....I think he's asking whether it's normal for the PLX unit to show "lean air" rather than the actual a/f ratio (16:1 or 18:1).
To the original poster, you might be better off concacting PLX... it's quite likely that you are going leaner than 20:1, and that's why it's showing "lean air" - it's possibly beyond the measurable range of the sensor...
Old Nov 14, 2005 | 04:50 AM
JOHN WAYNE's Avatar
Default Re: (Black R)
its normal for it to actually read "lean" rather than an A/F Ratio
Old Nov 14, 2005 | 05:14 AM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote"> it's possibly beyond the measurable range of the sensor...</TD></TR></TABLE>
yup, it's normal. Don't need no gas when you aint got no load.
Old Nov 14, 2005 | 07:52 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">it's normal.
when you're slowing down in gear with your foot off the gas, honda ECUs turn off the injectors, which causes LEAN or AIR to be displayed.</TD></TR></TABLE>
let me clarify. I said this because I have a PLX M300 and that's exactly what it is supposed to do.
lean - there is a trace of fuel but but it's less than the scale of the meter
air - the fuel content is less than the sensor can measure
Old Nov 18, 2005 | 09:24 PM
streetrays's Avatar
Relic1's answer is perfect
Old Nov 19, 2005 | 01:19 AM
itr1244's Avatar
Default Re: (streetrays)
no gas = no fuel
douh
jentee
May 18, 2008 07:41 AM
vietintegboi
Nov 15, 2006 08:57 AM
CoolRedXylophone
Apr 30, 2006 08:15 AM
basmasta7
Jan 28, 2003 09:17 PM
