axel nut thread
Old Nov 13, 2005 | 03:38 PM
89 pos's Avatar
Default axel nut thread
is it left hand thread or right hand thread
Old Nov 13, 2005 | 03:52 PM
loudassVTEC's Avatar
Default Re: axel nut thread (89 pos)
righty-tighty, lefty-loosy
Old Nov 13, 2005 | 03:56 PM
89 pos's Avatar
Default Re: axel nut thread (loudassVTEC)
broke my new wrench damn it
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC &raquo;</TD></TR><TR><TD CLASS="quote">righty-tighty, lefty-loosy</TD></TR></TABLE>
Old Nov 13, 2005 | 03:57 PM
Axle's Avatar
Be sure you bend the tabs out on the lip of the nut before you start trying to turn it.
Old Nov 13, 2005 | 04:01 PM
89 pos's Avatar
Default Re: axel nut thread (Axle)
i tryed to turn it left but it wont loosen and i did bend the tabs back out
Old Nov 13, 2005 | 04:03 PM
Make sure you are using a good 1/2 inch drive ratchet, and have someone hold the brake. Then use a floor jack handle or a piece of pipe on the end of the ratchet to give you more leverage. It'll come off.
Old Nov 13, 2005 | 04:04 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you are using a good 1/2 inch drive ratchet, and have someone hold the brake. Then use a floor jack handle or a piece of pipe on the end of the ratchet to give you more leverage. It'll come off.</TD></TR></TABLE>
lol, i have murdered so many rachets that way and also breaker bars, i finally have one breaker bar that hasnt given up on my yet....i payed enough for it(about $75)
Old Nov 13, 2005 | 04:06 PM
89 pos's Avatar
i was using a craftsman strate bar and a peice of steel pipe about 3 feet long
Old Nov 13, 2005 | 04:07 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 pos &raquo;</TD></TR><TR><TD CLASS="quote">i was using a craftsman strate bar and a peice of steel pipe about 3 feet long</TD></TR></TABLE>
if you broke the craftsman then take it back...it should still be under warranty
Old Nov 13, 2005 | 04:11 PM
Default Re: axel nut thread (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">
if you broke the craftsman then take it back...it should still be under warranty</TD></TR></TABLE>
You can always take a Craftsman tool back. Even if you find one on the street somewhere broke, you can take it back and get a new one.
Old Nov 13, 2005 | 04:13 PM
89 pos's Avatar
think after i get a new wrench tomarrow i will put some heat to it
Old Nov 13, 2005 | 04:15 PM
Heat, as in you're going to put a lot of force on it, or heat as in your going to burn that bitch with a torch??
Old Nov 13, 2005 | 04:17 PM
89 pos's Avatar
going to try to warm it up and get it busted loose
Old Nov 13, 2005 | 04:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 pos &raquo;</TD></TR><TR><TD CLASS="quote">going to try to warm it up and get it busted loose</TD></TR></TABLE>
Have you tried PB blaster or some WD-40 yet?
Old Nov 13, 2005 | 04:22 PM
89 pos's Avatar
wd yes /pb no
Old Nov 13, 2005 | 04:34 PM
projectTeG's Avatar
You can always take a Craftsman tool back. Even if you find one on the street somewhere broke, you can take it back and get a new one.</TD></TR></TABLE>
thats good to know...lol, because i found crastman ratchets in my car...lol
Old Nov 13, 2005 | 04:55 PM
94DOHCGsr's Avatar
Somone came into my work today and wanted us to get the nut off of his axel on his honda accord. He said he needed to get it off because he was changing the rotors. Thats a lot of work to change the rotor compared to the integra.
Any way, i tried an impact gun on it, and it didnt even budge. I was shocked. Then we tried a breaker bar on the 1/2 in 36 mm, and it did nothing. Crazy..even used penetrating lube. Couldnt get the sucker off. I hope he was able to get it off some other way.
Has anyone else not been able to get that nut off even with a impact gun???
Old Nov 13, 2005 | 04:57 PM
projectTeG's Avatar
Default Re: axel nut thread (94DOHCGsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94DOHCGsr &raquo;</TD></TR><TR><TD CLASS="quote">Somone came into my work today and wanted us to get the nut off of his axel on his honda accord. He said he needed to get it off because he was changing the rotors. Thats a lot of work to change the rotor compared to the integra.
Has anyone else not been able to get that nut off even with a impact gun???</TD></TR></TABLE>
i know of people that had that problem...they had to sit on the nut with the impact for like a hour to get it off.. i couldnt get mne off with a breaker so i took it to a shop up the street fomr my area and the dude poped it off in a second with this like super impact...lol
Modified by projectTeG at 2:29 AM 11/14/2005
Old Nov 13, 2005 | 05:24 PM
gsrious's Avatar
the extra steel pipe on the rachet(sp) never fails... just remember to pull up and not push down.
prison_snitch
Jul 3, 2006 04:16 PM
pumatec8
Jan 19, 2006 10:02 AM
Immanuel
Dec 26, 2005 12:11 PM
.water
Welding / Fabrication
24
Nov 8, 2005 08:50 PM
nocsyn
16
Nov 10, 2004 07:09 AM
