Honda S2000 Honda S2000
How does this Alignment look?, any information?
Old Nov 13, 2005 | 03:16 PM
SwpR's Avatar
Default How does this Alignment look?, any information?
Hey guys, well I got my car aligned about 2 weeks ago and finally got the chance to post a picture of the information of how the settings/degrees were and now are. he said the alignment before was TERRIBLY off cuz after the RA installation i didnt do this job b/c i alreayd needed new tires so i figured i'd save taht 60 bucks for once i got the new tires in and they are both complete now. Only thing is that the steering jerking motiion to the right seems a lot stiffer then to the left...why? more responsive to the right then to the left in other words and needs less rotation on the right side. The tires are re750's and are pretty good but seems a bit too soft/body rollish. when i jerk it left adn right car seems to react after i do it so causing the car to roll to the opposite side one extra time then it hsould n was like the so2s were. I got the chance to kind of see these tires on the freeway going at a decently high speed n the car seemed ok but a bit too wavy type feeling with these tires. Is it cuz i need to break them in more? or too much thread on it still? waht can it be? well, here is the picture. let me know.
BTW. i let the picture size stay as it was so you guys can see the very small numbers.
Old Nov 13, 2005 | 03:25 PM
Nishant's Avatar
Default Re: How does this Alignment look?, any information? (SwpR)
SO2's have better grip than RE750's. You will notice a big difference right there.
i would suggest running about 1.2-1.5 degrees of negative camber in the rear. That 2.3 is going to hurt your tire.
As far as the left and right thing, how is your dampening? (what settings are they at) Maybe they aren't set evenly. Get your car corner weighed. Most forget to do this but it is pretty imp't to handling when adding coilovers.
Old Nov 13, 2005 | 03:27 PM
Mr. Projekt's Avatar
* B A N N E D *
Factory specs are:
Camber:
F: 0 deg 30'
R: 1 deg 30'
Front caster: 6 deg
Total Toe(AP1)
F: 0 +/- 2 mm
R: 6 +/- 2 mm
Old Nov 13, 2005 | 03:35 PM
papa5murf's Avatar
Default Re: How does this Alignment look?, any information? (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">
not ture.. lol.... i got -2.5 in the rear and i have relatively even tire wear...
Old Nov 13, 2005 | 03:41 PM
* B A N N E D *
Default Re: How does this Alignment look?, any information? (03s2kblue)
Because it spends most of it's time leaning?
Old Nov 13, 2005 | 03:55 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">
not ture.. lol.... i got -2.5 in the rear and i have relatively even tire wear...</TD></TR></TABLE>
thats relatively even wear, you still have camber wear. it will depend on driving style mostly, which is why i recommended -1.5 to him
Old Nov 13, 2005 | 04:05 PM
papa5murf's Avatar
Default Re: How does this Alignment look?, any information? (Slideways2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">Because it spends most of it's time leaning?</TD></TR></TABLE>
si.. lol... but it depends on the combination of camber and toe.. to make it wear evenly...
Old Nov 13, 2005 | 04:06 PM
papa5murf's Avatar
thats relatively even wear, you still have camber wear. it will depend on driving style mostly, which is why i recommended -1.5 to him</TD></TR></TABLE>
i say he goes with a -2 in the rear.. (UK setting) with 0degree 20" toe... 0degree 40" total toe
Old Nov 13, 2005 | 04:13 PM
* B A N N E D *
Too much rear toe on an AP1 could worsen the already steep rear toe curve, but 40' is fine I guess. UK aligment on an AP2 works pretty well though.
Old Nov 13, 2005 | 06:04 PM
Nishant's Avatar
UK alignment works well if you drive hard. if you don't, it only eats tires
Old Nov 13, 2005 | 06:12 PM
* B A N N E D *
Dylan likes it when his wheels do the gangsta lean.
Old Nov 14, 2005 | 06:45 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">Dylan likes it when his wheels do the gangsta lean.</TD></TR></TABLE>
hell yeah.. cuase i'm just straight up gangsta.... whut whut... rofl
Old Nov 14, 2005 | 08:53 AM
p nut's Avatar
What size RE750's do you have in the rear? I mistakenly got 225's in the back when I got new tires, and the car really feels more unstable in the corners. By the time I realized my mistake, the exchange period had expired on the tires. Oh, well. A few more tiiiite burnouts and I'll be buying a new set.
Old Nov 14, 2005 | 09:25 AM
Nishant's Avatar
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">What size RE750's do you have in the rear? I mistakenly got 225's in the back when I got new tires, and the car really feels more unstable in the corners. By the time I realized my mistake, the exchange period had expired on the tires. Oh, well. A few more tiiiite burnouts and I'll be buying a new set. </TD></TR></TABLE>
how about just one long burnout
Old Nov 14, 2005 | 09:40 AM
p nut's Avatar
Default Re: (Nishant)
how about just one long burnout </TD></TR></TABLE>
I'm not that skilled. Speaking of, have you guys heard of this new Kumho tire with a cherry scent?
Old Nov 14, 2005 | 10:36 AM
WowOzYouRock's Avatar
Default Re: (P Nut)
first of all, its not scented ... just the smoke is red ... and thats old LMAO
they use it in Formula d ... just to burn out though NOT the actual drifting ...
Old Nov 14, 2005 | 10:38 AM
p nut's Avatar
I know, fool! I was just kidding around!
Old Nov 14, 2005 | 10:40 AM
Default Re: (P Nut)
sure you were ...
Old Nov 19, 2005 | 02:47 PM
SwpR's Avatar
Default Re: (P Nut)
sorry for the late response, haven't been able to come around lately. sorry guys, but back to ur question, its 245 and on teh freeway it doesnt seem all that steady as u can feel the car jerk a lil bit through the curves of the floor i guess.
Old Nov 19, 2005 | 09:11 PM
papa5murf's Avatar
Default Re: (SwpR)
check tire pressure... also... check to see if you still have those two little plastic thingies on your front bumper (in front of your front tires).... lot of people have taken them off or have had them fall off.... these two little plastic things actually help stableize the car at higher speeds...
Old Nov 22, 2005 | 04:53 AM
aklucsarits's Avatar
New User
Yikes!
OK front camber and toe looks good. But they do not appear to have measured the caster. Caster should have been checked and adjusted so that it's at least pretty even on both sides. Caster, toe and camber are all fully adjustable on the stock S2000 suspension.
The back is messed up. Your camber is out of spec on both sides - too much camber on the left, too little on the right. "Too much" rear camber is a good thing on this car IMO. 2deg + in the back is fine for street driving, but you want both sides to be even, not a full degree apart. That should be fixed to at least even the two sides out better. Your rear toe is fine - within factory spec at .5 deg total, and pretty even left and right. (But of course, when they mess with the camber to fix that, they will whack the toe setting and the whole rear end basically has to be re-adjusted.) Toe and Camber are both fully adjustable on the rear of the s2000.
The "jerking" motion to one side could be due to a large variance in caster angle between the two sides. The lopsided rear camber could be a factor as well in hard turns.
Andrew
Old Nov 25, 2005 | 02:31 PM
SwpR's Avatar
Default Re: How does this Alignment look?, any information? (aklucsarits)
thanks! when i get teh chance iw ill give them a call and see what can be done.
User 5426
Suspension & Brakes
Jan 30, 2006 10:07 AM
sshaikh01
23
Apr 7, 2003 06:20 PM
MugenPoweredLude
Dec 29, 2002 03:35 PM
mickey513
Aug 27, 2002 02:03 AM
