Will Ford probe v6 rims fit an ITR??
I just picked up some steelies,, 15x6, 5 x 114.3.... off a probe v6..
I just got them and the Offset looks off.... as if the tires will be sticking out,,, does anyone know if they will fit an ITR????
please let me know
thanks
Tyler
please let me know
thanks
Tyler
The stock tires on those rims are not the correct height for an ITR, if you're referring to the last generation.. also the GT came with 16's, not 15, but the regular Probe of that generation came with 15's and 205/55 15 tires.
Im not refering tot he tires,, i just bought rims,, thats all....
I have the right tires,, so i just needed to know if the rims will fit!
i think the offset on the probe gt rims are like 37 offset or something like that
i owned a 93 probe gt, but they came with 225/50/16 tires
the 15's, i dont know about, but they probably will fit fine
you dont need tires to test fit them.. if theres no hub clearance problem, then you can somewhat visualize where tire would end, the best i can suggest.
"Probe stock wheels are 5 x 114.3 with a 40mm offset"
Got this from this message board:
http://cafeutne.org/motet/gues...9+-25-
I'm not sure how accurate that is, but hope it helps.
If you're not extremely lowered, you should be ok. Just FYI, the Rota SS's come in 40+. Double check this in the tire forum, as I'm not that well versed when it comes to wheel fitment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">you dont need tires to test fit them.. if theres no hub clearance problem, then you can somewhat visualize where tire would end, the best i can suggest. </TD></TR></TABLE>
The rim may not clear the caliper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal ITR »</TD></TR><TR><TD CLASS="quote">
The rim may not clear the caliper.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATgrills.com »</TD></TR><TR><TD CLASS="quote">so does that mean it will fit </TD></TR></TABLE>
Why is this so difficult for you to do? Five minutes and you'll have your answer.
VTECTIME
Sep 8, 2002 07:09 PM
