euro r cluster
Old Nov 13, 2005 | 09:27 AM
EuroKing99's Avatar
Default euro r cluster
has anyone tried to install a euro r cluster in their 6th gen accord ex coupe 4cyl. when i installed it into my car, the backlight only turned off when i turned on my headlights and stayed on without the keys in the ignition. also, the tach did not function. is it because i need a different harness or connectors or what? any info would be useful. the euro r cluster is an oem honda euro r from a 2001 jdm accord euro r
Old Nov 13, 2005 | 09:33 AM
fw190bvi's Avatar
Default Re: euro r cluster (EuroKing99)
maybe its because the signal from the USDM ECU isnt the same type that the tach is capable of reading.
and news flash, why would you put that cluster into your car....the tach will be waaaaay off
Old Nov 13, 2005 | 02:19 PM
EuroKing99's Avatar
Default Re: euro r cluster (fw190bvi)
i will eventually install a euro r motor into my car. does that mean that i need to change the ecu or can i get some kind of conversion thing
Old Nov 13, 2005 | 02:50 PM
krispyaccord's Avatar
I would like to see a couple pics of this cluster if you can get em'
Thanks
Chris
Old Nov 13, 2005 | 03:10 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EuroKing99 &raquo;</TD></TR><TR><TD CLASS="quote">i will eventually install a euro r motor into my car. does that mean that i need to change the ecu or can i get some kind of conversion thing</TD></TR></TABLE>
You have a SOHC...EURO R is DOHC.
Yes...ECU has to be swapped.
Old Nov 13, 2005 | 07:35 PM
EuroKing99's Avatar
Default Re: (krispyaccord)
ill post up some asap
Supa Troopa
62
Jul 19, 2023 10:07 AM
digi198816
Mar 21, 2010 12:43 PM
triple5soul8781
Aug 7, 2008 05:46 AM
vbkapousidis
Honda Civic (2001 - 2005)
Mar 3, 2008 09:58 PM
89DXDann
Jun 4, 2004 11:38 PM
