Another FAL fan question ...YES! I searched!
Old Nov 13, 2005 | 01:34 AM
MiraiZ's Avatar
Default Another FAL fan question ...YES! I searched!
A quick question
I looked back at the past threads, and it seems that the main reason people got the FAL fans is to fit a bigger radiator. Aside from its smaller form factor, does it have any performance benifits over the OEM shrouded fans?
Does it help cool the engine better?
-Secondly, These seem to be puller fans, and I read conflicting statements saying that they polarity can and cannot be reversed. CAN they in fact be reversed to make them into pusher fans? If so, what is the process? Do I have to chop the plugs off and reattach them backwards, or are people simply mounting the whole assembly backwards?
-Finally, I've never mounted fans on any car. I am assuming its not too involved of a process. How easy/hard is it? How long would it take someone who has never done this?
Any response (except flames or sarcasm) will be appreciated.
Old Nov 13, 2005 | 02:46 AM
eggiel's Avatar
more air than any other fan it cools down the car faster ,the looks is nice and about polarity i dont know i saw one but have'nt have one yet but if the case is that push air than extract it put it in the front of yo radiator
Old Nov 13, 2005 | 02:50 AM
MiraiZ's Avatar
Old Nov 13, 2005 | 03:52 AM
2point2's Avatar
Default Re: (MiraiZ)
the fan will not work the way it is intended to work if you switch the polarity. it's obvious when you look at the profile of the fan blades.
by the way. a flexalite fan is EXACTLY the same.. same CFM last time i checked.. and looks the same too!! it just doesn't come with the fancy brackets or the oem style plug. it's your money though.
to answer your last question - the FAL is strait forward.. i bet it comes with fancy instructions too. As for the flexalite, it comes with special zip ties that go through the rad fins.. you'll know what to do.
Old Nov 13, 2005 | 06:02 AM
itr1143's Avatar
the fal fan is made by flex a lite they are they same thing..one of them (the fal ) is direct fit and as factory plugs the other (flex a lite) is unaversal fit and need to be hard wired.same fans one is cheaper then the other and they both work great..most poeple that use them need them for the tight space left by installing a turbo...i see no need to change from stock fans unless there is no room for them..
Old Nov 13, 2005 | 06:03 AM
BoostR41's Avatar
Default Re: (2point2)
who does make pusher fans?
Old Nov 13, 2005 | 07:43 AM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (BoostR41)
what about installing them as pushers in front of the condenser? And also these fans only come on when the car is idling or when stop? correct if im wrong.
Old Nov 13, 2005 | 01:41 PM
D@nnY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">the fan will not work the way it is intended to work if you switch the polarity. it's obvious when you look at the profile of the fan blades.
F -Flex
A - A
L- LITE
fal is flex a lite ...nice write up tho they should sticky it
Old Nov 13, 2005 | 02:42 PM
Finland's Avatar
I bought the fal dual fan setup not because I wanted to run a bigger radiator, but because I didn't want to hack up the stock shrouds to make room for the turbo. They have been excellent and have performed flawlessly for over 4 years. They are advertised to flow 30% more than stockers, I believe it. I have never had any overheating issues, even after 18 runs at the dragstrip, one after another. I run the factory stock radiator.
Old Nov 13, 2005 | 04:23 PM
_gurusan_'s Avatar
Default Re: (Boondock Saint)
WHy spend all that money?
I just got a 12'' slimfan for 50 bucks shipped on ebay.
Old Nov 13, 2005 | 06:40 PM
HT Black OPs
Default Re: (_gurusan_)
contact b18bturbo, he has 10" 12" for 55 and 60 dollars. there push/pull slim fans, which im gonna get here very soon. spending over 200 dollars for fans is ridiculous.
Old Nov 13, 2005 | 09:33 PM
_gurusan_'s Avatar
Default Re: (00IntegrAllmotoR)
I spent 200 dollars total on my aluminum race radiator/slim fan setup.
Old Nov 16, 2005 | 01:55 AM
MiraiZ's Avatar
so can I just flip the plug around, or do I need to chop the connecter off and reattach it backwards?
Old Nov 16, 2005 | 03:57 AM
projectPSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _gurusan_ &raquo;</TD></TR><TR><TD CLASS="quote">WHy spend all that money?
I just got a 12'' slimfan for 50 bucks shipped on ebay.</TD></TR></TABLE>
Been there done that, electrical connectors on the fans them selves melted and the plastic on the fans was starting to melt also from being by the turbo. Got fal pusher/puller fans and no problem.
There are some models that the polrity can reversed and then there are some that are direction specific, make sure u specify what u want when u buy them.
Old Nov 17, 2005 | 03:02 AM
MiraiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">so can I just flip the plug around, or do I need to chop the connecter off and reattach it backwards?</TD></TR></TABLE>
ne1 else?
Old Nov 17, 2005 | 03:09 AM
slammed_93_hatch's Avatar
IMO it not a good idea to install fans as pushers. at a certain speed, they become a hindrance to the air flow
Old Nov 17, 2005 | 03:18 AM
Dee's Avatar
Dee
Mirai -- If you do not want to chop your wire harness you can do what I did when I installed my old C&R radiator with a SPAL fan. I made an adapter mating a plug from a junkyard Honda to the appropriate plug for the fan. Cost -- $3 (fan plug from the boneyard was free and the 2-pack of plugs cost me 200yen from Autobacks. I did this because I knew I would be upgrading to a new car eventually.
Jan 12-16 I will be in Tokyo for TAS so we need to find a way to hangout this time.
Oh yeah, SPAL funs are damn good too If you are looking for a new rad/fan combo, my C&R/SPAL combo needs a new home.
702SI
Jul 4, 2013 07:20 AM
zapzach
Apr 19, 2013 03:57 AM
ReVeNgEd-SoN
Feb 9, 2010 04:22 AM
iwantspeed
Jan 24, 2007 10:37 PM
HondaCutter
Jul 24, 2003 12:38 PM
