Parts 4 Sale ALL at OBO...Moving and need it gone. Located in Portland.
Old Nov 13, 2005 | 12:24 AM
HondaBondMan's Avatar
B A N N E D
Default Parts 4 Sale ALL at OBO...Moving and need it gone. Located in Portland.
FOR SALE:
____________
OBD2 B-Series Distributor $150
B-Series Vehicle Speed Sensor VSS $20
Resistor Box $20
OBD2 Injectors $40
B16A ODB1 Throttle Body COMPLETE $80
B16A2 ODB2 Throttle Body COMPLETE $80
00 B16A2 EVAP Solinoid $20
99 GSR/Integra IAT Sensor $10
5-Zigen Fireball muffler welded to 2.2" staright piping fitted to EK $100
B-Series Oil sender $10
92-95 Single Radiator w/ Overflow w/ 00 civic condenser fan and hoses $60
No Name 89-00 Civic 91+ Integra Lowering Springs $40
00 B16A2 Crankshaft $25
99 GSR B18C Rocker Arms w/ Shafts $70
00 Si clutch master cylinder w/resivour & slave cylinder $30
00 LS Water pump (10k) 3k miles $20
00 Si prop valve (needed for 4-wheel disc upgrade) $20
96-00 Civic stereo mount kit (maybe fit other cars too) $10
96-98 silver hood $25
96-00 Civic Blower Motor for heat and such $20
00 Civic power steering rack $40
00 Civic Si B-Series Upper Transmission Mount $20
22mm Mugen rear sway bar w/00 si end links and reinforcment plates $100
00 Civic stock floor jack w/ tools $10
96-00 Civic Armrest Dark Gray no armrest pad $10
96-00 Civic Armrest eliminator Dark Gray $10
EG Hood Primered OEM $40
D-Series OE Wires from a 00 15k $15
b20 head gasket $50
99-00 Civic Door SHELLS ONLY BOTH $50
GSR Headgasket NEW $40
B-series AC Bracket Pulley JUST THE PULLEY AND ARM $10
Rear brackets for 99-00 Civic Center Console Bezel $10
Battery tie down OEM $15
95 GSR Block w/ some parts & Tranny
- Spun Bearing on 1 rod. Could be polished or replace crank.
- Missing Head
- Transmission has like 5th and 3rd gear gone
Project I started and dont have time. $1000 OBO
_____________
USED ITEMS
_____________
Shopvac $20
Stand up battery charger $15
engine stand $25
Craftsman creeper $10
Kitchenaid Washer & Dryer Used Work PERFECT....$300
Old Nov 22, 2005 | 12:21 AM
Sector9guy's Avatar
Default Re: Parts 4 Sale ALL at OBO...Moving and need it gone. Located in Portland. (HondaBondMan)
Buyer beware! I've been waiting for FOUR months for a set of LMA's from Del (Hondabondman) and have been getting the run around. Still no LMA's at my door...
*update* After waiting FIVE months for a set of GSR lma's, I FINALLY got them. Just a heads-up...
Modified by sector9guy at 11:29 PM 12/5/2005
HondaBondMan
Northwest (Sales)
Jan 22, 2006 05:16 PM
HondaBondMan
Oct 22, 2005 11:31 PM
