Need help ASAP! - how to remove this fender bolt - extremely pain in the azz. bent bolt
Old Nov 12, 2005 | 08:35 PM
verbose axsassin's Avatar
Default Need help ASAP! - how to remove this fender bolt - extremely pain in the azz. bent bolt
This bolt right here is bent up to a shape of an "L" instead of "l"
no way i can screw the nut out, how do i remove this?
already chipped my fender paint trying to straigthen the bolt. and also damaged the threds trying to straigten it out. i have no ******* idea why the body shop put this bolt on. they should have used the OEM clips.
Old Nov 12, 2005 | 08:38 PM
bobyahead's Avatar
Default Re: Need help ASAP! - how to remove this fender bolt - extremely pain in the azz. bent bolt (verbose
my homey had that exact same problem... but at least yours is right there. he had a ******* bolt all up inside there. where they are suppose to be clips... they ******* put a bolt!!! i couldn't get my hands in there. but i fucked dremeled the hell out of it. such a pain in the ***
Old Nov 12, 2005 | 08:39 PM
Leutenegger's Avatar
A deep soket or get a set of pliers and be nd that **** failing that angle grinder then socket;.
Old Nov 12, 2005 | 10:50 PM
ok finally got it out.
broke 3 of my dremel cutting pad trying because the fender was giving me a hard time, and i dropped my dremel and crack the cutting blade in half 3 ******* times.
anyways, after i removed 4 bolts from my fender, it made everything easier. and after 5 minutes of dremel, i got this.
thanks to dremel.......
and now i get to install it the right way and used the clips instead of 6 ******* bolts.
pain in the azz.....
I like my R
Aug 24, 2023 08:56 PM
ADeKK
Aug 7, 2010 04:10 PM
truevietluv636
11
Jun 6, 2007 07:13 AM
is3oo
Oct 4, 2003 01:48 PM
hellas
Jan 21, 2003 12:33 PM
