95 accord helppppp
95 accord ex, whenever it rains, the driverside floor gets really wet from the rain, sometimes there will be massive amout of water in there, my stepdad took it to auto shops but they cant find the problems, do anyone have the same problem? please share some advices. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jin05 »</TD></TR><TR><TD CLASS="quote">95 accord ex, whenever it rains, the driverside floor gets really wet from the rain, sometimes there will be massive amout of water in there, my stepdad took it to auto shops but they cant find the problems, do anyone have the same problem? please share some advices. thanks</TD></TR></TABLE>
have u had the windshield replaced lately?? possibly the moon roof drain tube are plugged ???
Another place I might suspect is the drivers' door. If it had been worked on previously, the moisture barrier may have been damaged; allowing water leaking through the door leaking into the compartment from just behind the door trim panel.
P
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams »</TD></TR><TR><TD CLASS="quote">Another place I might suspect is the drivers' door. If it had been worked on previously, the moisture barrier may have been damaged; allowing water leaking through the door leaking into the compartment from just behind the door trim panel.
P</TD></TR></TABLE>
good point P-
,,it skipped my memory ,,some techs just remove that plastic part totally off not realizing the consequences it could have ..
P</TD></TR></TABLE>
good point P-
thanks for the advice, i ma check on dat, but from wat im knowing its never been fixed. like we took it to the shop 3 times with different places, they cant find anything wrong or any leaks but everytime it rains if it rains hard, its like flooding, it have like half inch to an inch of water... dont the wtf is going on.
P</TD></TR></TABLE>
My guess... same prob with the pass. side of mine.
P</TD></TR></TABLE>
2camsaam
Nov 14, 2004 08:10 PM
