94 Honda Accord Lx
Old Nov 12, 2005 | 05:44 PM
Defcon2030's Avatar
Default 94 Honda Accord Lx
94 Honda Accord LX 2.2l SOHC (not a v-tec). I replaced the sparkplugs but when i took out #3, i noticed that the socket piece was covered in oil when i removed it from the hole, and so was the head of the spark plug when i took it out of the wrench bit. each time i put the socket bit into the hole it came out doused in oil. not sure what the implications of this problem are.... can someone help me?
Modified by Defcon2030 at 8:42 PM 11/12/2005
Old Nov 12, 2005 | 05:52 PM
BLKFLSH's Avatar
Default Re: 94 Honda Accord Lx (Defcon2030)
http://www.cb7tuner.com/vbb/sh...+tube
This thread explains everything you need. However some people say to try changing just the oil tube seals under the valve cover first and see if that solves the problem. If not you need to do the major o-ring job. The ball is in your court, so to speek.
Old Nov 12, 2005 | 05:57 PM
BLKFLSH's Avatar
Default Re: 94 Honda Accord Lx (BLKFLSH)
This may not apply to your engine. I know it does for 90-93. Someone else may have to confirm it for your engine. Are you sure it's a 94, I haven't heard of this happening to 94s before?
Old Nov 12, 2005 | 07:40 PM
BLKFLSH's Avatar
You need to get DH or P to reply to your problem then, so they can verify.
Old Nov 12, 2005 | 07:55 PM
P_Adams's Avatar
If the Valve Cover Gasket has never been changed (since you bought it), now might be the time to entertain the thought of having the valves adjusted while it's apart. (periodic maintaince item).
To do the valve cover gasket job, it requires several parts to ensure you don't have to re-do anything. they are:
1) Valve Cover Gasket (#5)
2) Spark Plug well 'O' Rings (#7)
3) Valve gover grommets (#15)
They are all part of #1 Kit
http://www.hondaautomotivepart...COVER
P
Sopheap Sao
Lighting
Mar 11, 2016 03:43 PM
Witness7
Dec 3, 2012 08:44 AM
portugueboy10
Sep 3, 2012 05:00 PM
LUiS010606
Feb 7, 2009 12:40 AM
