Who has used the Phantom Grip aluminum rocker arms?
Old Nov 12, 2005 | 04:40 PM
SRDrag's Avatar
Default Who has used the Phantom Grip aluminum rocker arms?
Anyone?
Looking for feedback and opinions from those with firsthand experience with the PG rocker arms.
Old Nov 12, 2005 | 06:12 PM
sheepey's Avatar
DonF I believe has used these. You should ask him about em.
Old Nov 12, 2005 | 09:17 PM
RPRacing's Avatar
we have first hand use of them on 2 cars. they work great.
Old Nov 13, 2005 | 05:02 AM
D-tuned's Avatar
Default Re: (RPRacing)
I'm running them in my car I'm changing the setup again. I'll let you know how of any gains when i redyno
Old Nov 13, 2005 | 08:53 AM
1 2 NV's Avatar
Default Re: (D-tuned)
i havent noticed anything different in my setup. i went slower in 05 mostly because i overslicked the car. it was a pain in the *** to get it to run at idle, but we finally got it.
Old Nov 13, 2005 | 09:55 AM
sheepey's Avatar
are you guys just running the vtec lobe? or all 3? Cause honestly, i dont see a damn point in this type of setup...
Old Nov 13, 2005 | 11:52 AM
Fkned's Avatar
Default Re: (sheepey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepey &raquo;</TD></TR><TR><TD CLASS="quote">are you guys just running the vtec lobe? or all 3? Cause honestly, i dont see a damn point in this type of setup...</TD></TR></TABLE>The benefit of this type of set-up is the reduced pumping losses and higher reving ability achived by reduceing the valvetrain mass considerably,no lma's and the lower spring pressures needed to control valve float.Free hp doesn't make you happy?
Old Nov 13, 2005 | 12:06 PM
sheepey's Avatar
Default Re: (Ed's Racing Heads)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed’s Racing Heads &raquo;</TD></TR><TR><TD CLASS="quote">The benefit of this type of set-up is the reduced pumping losses and higher reving ability achived by reduceing the valvetrain mass considerably,no lma's and the lower spring pressures needed to control valve float.Free hp doesn't make you happy?</TD></TR></TABLE>
Oh ok, so you can run lower spring pressure? I was under the impression you had to run teh LMAs still....Thanks for clearing it up.
Old Nov 13, 2005 | 12:59 PM
J-Brooks's Avatar
How much does a set of these run?
kloscivicsi
Honda S2000
14
Feb 24, 2007 07:23 PM
J-Spot
Jul 6, 2006 03:55 AM
Doeboy
Acura TL, RL & ZDX
Nov 21, 2004 12:15 PM
street dreams
66
Oct 20, 2004 05:55 PM
mikestypeRR
Sep 4, 2004 01:03 PM
