timing belt change, 93 accord
Old Nov 12, 2005 | 04:14 PM
jacrandon's Avatar
Default timing belt change, 93 accord
Changing timing belt, on a 93 accord, with 2.2L, engine code #f22A1. Trying to make sure i have #1 cylinder at TDC, looks to be a red mark on flywheel, not well defined, and cam pulley is "up". How do you get crankshaft pulley off? I don't have an impact wrench. (no air compressor)
Old Nov 12, 2005 | 04:30 PM
BLKFLSH's Avatar
Default Re: timing belt change, 93 accord (jacrandon)
If you can find something like a long pencil or something to stick down the #1 plug hole if it hits the piston just under the head (sparkplug hole), you've got it. But don't drop it in there please!!!
Old Nov 12, 2005 | 04:39 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacrandon &raquo;</TD></TR><TR><TD CLASS="quote"> Trying to make sure i have #1 cylinder at TDC, looks to be a red mark on flywheel, </TD></TR></TABLE>
The white mark indicates TDC. The red is for setting ignition timing.
Old Nov 12, 2005 | 04:45 PM
jacrandon's Avatar
Default Re: timing belt change, 93 accord (Chiovnidca)
I at first had the flywheel on the white mark, and when I took off top cover of timing belt cover, the cam pulley was not in the up position. when i turned it to (up), then the flywheel mark went to red.
Old Nov 12, 2005 | 06:47 PM
deserthonda's Avatar
if u are at the white mark on the flywheel ( top dead center ) and if u are on # 1 cylinder , up mark facing up ,look at the back of the cam pulley ( valve side ) there are 2 notches they should align with the head, if not , cam timing is off ...now u can still have the white mark line up at the flywheel but u could be at cylinder # 4 then the up mark on the cam pulley would be facing down ..
acmoc
11
Mar 8, 2012 05:09 PM
ukrkoz
23
May 24, 2009 04:26 PM
KL14
Nov 7, 2005 09:11 AM
