throttle body gasket install
Old Nov 12, 2005 | 03:45 PM
88da3's Avatar
Default throttle body gasket install
I have a question on how to properly install the throttle body gasket. The helms doesn't have a procedure, just says to replace. I know it is pretty straight forwards but my question is replaced the gasket, torqued everything down but my idle is a bit high(1000rpm) even with the adjustment screw closed. I just wanted to know if i need to use hondabond on the mating surfaces of the tb and IM before applying the paper gasket?
trailblazer
Jul 9, 2018 08:22 PM
DerekHollister
Apr 3, 2016 05:01 PM
bigweedy
Dec 29, 2009 01:13 PM
Jerry
Feb 9, 2003 07:46 PM
