GSR front sway bar install in eg hatch
I have installed the front gsr lca's and i have a b series swap, headers, and exhaust. Is the gsr front sway bar a direct bolt on, because I'm having trouble fitting it in place. Do i have to disconnect the shift linkages as well as the cat??? Anyone know of a thread or website with details and pics? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej0513 »</TD></TR><TR><TD CLASS="quote">you need to disconnect the shift linkage and the exhaust catback. itll bolt right on.</TD></TR></TABLE>
yep exactly
and fyi: 92-95 eg civics and 94-01 integras share many of the same suspension components....the sway bar being one of them
yep exactly
Thank you much...I've never had a front sway bar on any of my cars, figure i'd try it.
I was having trouble 'seeing' the place it went with the car only inches off the ground using jackstands.
Once again H-T does the trick
litterbox
17
Mar 15, 2005 08:02 PM
