What is 2001 CL coupe wheel's PCD?
I was wondering if it is same as my ITR's 114.3 mm X 5 with offset around 50mm?
Next question is if same, can it use my wheels since CL's OEM is 16s to 15's?
I have set of snows on accord steelies from Tirerack laying around for 5 yrs
so just to see if I can use it on my co worker's CL .
The Stock Type-S wheels are 17inch with a +55 Offset
5x114.3 is the bolt pattern
Dont go lower than a +45 offset from what I hear, and I dont think anything smaller than 16inches will work.
Check http://www.Acura-CL.com for more info and exact numbers
For the 2nd gen CLs and TLs, anything that's 5X114.3 basically fits on...but nothing under 16, 15 won't clear the calibers and all...and try to keep the offset close to stock as possible - around the 50's.
alwaysinstock
26
Jul 24, 2013 11:44 AM
Teh_Oven
Jan 31, 2005 10:13 PM
