Boost integra LS
hEY guys i know im not in the forced induction forum but im asking the question in both....I was wondering i have a 98 itntera LS and i already have my T3 turbo setup with a equal length manifold and a the front mount...i have also a boost controller and turbo timer...plus i just ordered 8:5:1 pistons and also turbo rods with turbo cams and cam gears.....the thing that im just asking is wat size fuel injectors do u think would be needed to run..and also should i invest in a fuel rail and fuel pump and feul regulator or do you think all those would not be necessary do you think just the inejectors would be necessary please give me your feedback??? thank you
Im not a master of boost but all that you will need is injectors. Decide how much horsepower you want and that will help determine the size you need. As for the fuel pump Id recommond getting a Walbro 255, inexspensive insurance over the stock fuel pump. You will not have to change the fuel rail or regulator till you get around 500 horse power, but again Im not a boost master just did alot of search on H-T!! ( search is your best friend on here!
Sam
Go to boosted-hybrid.com, forced induction forum, second sticky, kick *** info1
Modified by B-Hatchie at 7:41 AM 11/12/2005
)Sam
