NRG Tech does it again 10.98@117
Well my car has been going through changes for the past 2 years. I finally get the car back and we went to test and tune at e-town last night for a few shake down runs with the car to see what it does. The car still has weapon r circuit pro coil overs with blown shocks, so we were hoping for the best. Here is the set up and times from last night. Oh yeah, the car caught on fire after i ran my second time on the return trip from the end of the track.
The car made 682whp@29 psi and thats what we were running at the track on 24.5x8x13 m&h's on lensos (99 Civic coupe ex)
This set up:
83mm gsr block w/ darton mid sleeves
cp 9:1 pistons w/ pauter rods
gsr head w/ 01 type r cams
skunk2 valve springs and retainers
ferrea ss .5 oversize valves
jg elderbrock im w/ str 68mm tb
gsr tranny w/ a quaife lsd
act 6 puck w/ act prolite flywheel
full race top mount manifold
precision 1000cc injectors
t3/ t67 H.O. w/ p wheel
tial 44mm wastegate
precision 750hp intercooler
4 inch down pipe
3 inch exhaust
Msd SCI ignition
the first run was:
12.1@132 (bogging off the line and missing 3rd gear 3 times)
the second run was:
(for everybody that hates to read, the 10 sec past was just 1,2,3rd gears and 4th died out with basically no power, only gained 7mph the second half of the track but still went 10.98)
r/t:.557
60:1.816
330:4.828
1/8:7.113
mph:110.82
1000:9.132
1/4:10.981
mph:117.25
we dont know what happend but on the return trip a ball of fire came from underneath the hood. The motor and turbo set up is find but the hood, wiring, grill burnt. Pics of the car are on http://www.nrgtechracing.com, its the black coupe under Kory
Modified by 1fastgsrturbo at 4:32 PM 11/12/2005
Modified by 1fastgsrturbo at 8:52 PM 11/15/2005
This set up:
tial 44mm wastegate
4 inch down pipe
3 inch exhaust
Msd SCI ignition
the first run was:
the second run was:
r/t:.557
60:1.816
330:4.828
1/8:7.113
mph:110.82
1000:9.132
1/4:10.981
mph:117.25
1st,2nd, and 3rd gear was perfect to me and when i went to put it in 4th gear the car just died out. It sounded like a fuel or spark problem. I just stayed in it enough to past the 1/4 mile so i could get off the track. The car had alot more in it
Thats whats wierd. I coasted to the last turn for the return trip on the brakes the whole way and when i was on my way back POOF. It sucks but i know that car is capable now which makes all the time and money worth it and makes me wanna keep on going.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hurtramp »</TD></TR><TR><TD CLASS="quote">a 10.98 second 600+hp honda???
isnt that kinda...sad?</TD></TR></TABLE>
Did you read the guys post at all?
Congrats guys, the T67 H.O is makin some good *** power!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hurtramp »</TD></TR><TR><TD CLASS="quote">yeah, it ran fine when it made the 10.9 but it caught fire on the return trip.</TD></TR></TABLE>
we dont know the cause of the fire yet, and we wont know till we get the car back to the shop. we have a couple ideas as to what happened. but all of that is speculation at this time. its nothing major, everything is fine and in tact. just the top of the harness is singed.
and as far as the run yes it was only a 10.9 run at 117, im just happy about the 1/8th mile. 110.8mph, on stock struts and 24.5" slicks with 11lbs of air in them cause they were leaking with anything else below that. not to mention this is also is a full body coupe with nothing but the back seats out, with steel hood, trunk and all.
dont worry this car will be back up and running real soon with some suspension work...
for everybody (really just HURTRAMP) that hates to read, the 10 sec past was just 1,2,3rd gears and 4th died out with basically no power, only gained 7mph the second half of the track but still went 10.98. so if anybody thinks thats sad escpecially for a heavy coupe second time down the track please show me you can do better
..........This Car is a beast. I got the chance to see this monster in action
@ E-Town and to see it pull 10.98@ 117 was sick bro. Props to 1fastgsrturbo
for holdin it down as NRG-TECH does it again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fastgsrturbo »</TD></TR><TR><TD CLASS="quote"> Pics of the car are on http://www.nrgtechracing.com, its the black coupe under Kory
Modified by 1fastgsrturbo at 4:32 PM 11/12/2005</TD></TR></TABLE>
Actually its under Cory..LoL.. nice times
hope you get the kinks worked out!
thanks terry. all we gotta do now is find out what caused the fire and fix the damages. Then its new suspension and some weight reduction. When the trucks were putting out the fire i wanted to die, i thought it was all over b/c nobody actually new the car was on fire except for me so it burned a little bit longer then it should've. When my boy juan got my time slip for me and i saw the 10.98@117 a smile came to my face and all i could think about was fixing it and doing it all over again.
Pics will be up soon of the before and after pics of my car. It really doesnt look that bad
the damage is very very minimal, just singed the top of the injector harness,and dizzy wires. the most expensive part that was damaged wa the hood, cowl amd grill on the bumper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fastgsrturbo »</TD></TR><TR><TD CLASS="quote">AT least now i can kick myself in the *** and buy a carbon fiber hood and trunk during this off season
Ricer!!!!!
I have both on my car
</TD></TR></TABLE>Ricer!!!!!
