built gsr motor
Old Nov 11, 2005 | 04:44 PM
JDM4DR.GSR's Avatar
Default built gsr motor
i have a built gsr motor for sale motor comes with tranny, axles, wiring harness, ecu
head has:
slight port and polish
3 angle valve job with rev valves
new 06' street/strip crower cams
skunk 2 cam gears
crower valve springs and retainers
arp head studs
skunk 2 manifold
type r throttle cable
gsr throttle body
str fuel rail
aem fuel pressure regulator
dc sports 4-2-1 header
gsr injectors
block has:
.20 over jdm itr pistons
race engineering block gaurd
arp rod bolts
gsr rods
new water pump
new oil pump
clevite rod and main bearings, new thrust washers
new timing belt
new timing belt tensioner
act 10.5 lb flywheel
block has been hot tanked and high temp paiinted
motor has all new gaskets,have obd2 wiring harness, comes with obd2 type r ecu, but has obd1 distributor, comes with all motor mounts, solid motor mount inserts, has type r shift linkage with type r shifter, have unethane linkage bushings, all parts in motor are new and have receipts for everything and the machine work
asking $4,000
please call aaron 443-865-4853 all offers will be considered.........need to sell asap
Modified by JDM4DR.GSR at 6:39 AM 1/15/2006
Old Nov 12, 2005 | 03:12 PM
JDM4DR.GSR's Avatar
Default Re: built gsr motor (JDM4DR.GSR)
bump must sell
Old Nov 24, 2005 | 01:59 PM
JDM4DR.GSR's Avatar
bump..............................asking $4500...............swap also comes with another set of brand new crower 403's, and brand new rev valve springs and retainers..............must sell.......
call Aaron 443-865-4853
Old Jan 14, 2006 | 09:40 PM
JDM4DR.GSR's Avatar
bump have family emergency please need to sell
Nickb257
Northeast (Sales)
Sep 4, 2011 08:18 AM
Nickb257
Northeast (Sales)
Aug 23, 2011 04:18 AM
Nickb257
Aug 23, 2011 04:15 AM
onesikdb8
Apr 6, 2007 01:59 PM
JDM4DR.GSR
Jul 16, 2006 12:13 PM
