Suspension & Brakes Theory, alignment, spring rates....
Do you need an alignment after changing tires and/or rims?
Old Nov 11, 2005 | 02:29 PM
TurboEM1's Avatar
Default Do you need an alignment after changing tires and/or rims?
Hey guys just wondering if you change tires or rims or both, do you need to get an alignment again? I would guess no since you are at the same ride height. I would guess no even if the tires/rims were a different size since there all the same it would sit the same. Anyway what do i know. Thanks
Old Nov 11, 2005 | 02:49 PM
Jamez's Avatar
Default Re: Do you need an alignment after changing tires and/or rims? (TurboEM1)
No, tires and wheels just get balanced and then put on the car. You can't affect alignment settings from just removing a wheel.
Old Nov 12, 2005 | 07:44 PM
Fuster_Cluck's Avatar
Default Re: Do you need an alignment after changing tires and/or rims? (Jamez)
I was wondering the same thing. Now I can grab the 2 other sets of wheels I want for the hatch (4 total)
Old Nov 13, 2005 | 08:35 AM
TurboEM1's Avatar
Default Re: Do you need an alignment after changing tires and/or rims? (Hybrid93Hatch)
ok sounds good. now i dont have to worry swapping rims and tires from summer to winter and car to car. Thanks
Old Nov 14, 2005 | 02:52 PM
.water's Avatar
well real question is does tire size changes alignment?
from 195-55-15 to 195-50-15
Old Nov 14, 2005 | 03:34 PM
TurboEM1's Avatar
Default Re: Do you need an alignment after changing tires and/or rims? (zzzvtakzzz)
no tire size wont effect alignment
Old Nov 14, 2005 | 03:43 PM
.water's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">no tire size wont effect alignment</TD></TR></TABLE>
so camber will be still same? even it gets smaller or bigger?
Old Nov 14, 2005 | 03:59 PM
TurboEM1's Avatar
camber should stay the same
michael-crxsi
Jun 12, 2010 06:14 AM
yuning83
Honda Civic (2006 - 2015)
May 10, 2007 10:45 AM
Green_is_the_new_gold
May 4, 2007 05:18 AM
curveit
Nov 2, 2005 02:26 PM
LiLn81224
Feb 17, 2003 09:08 AM
