PR3 vs PW0
i just ordered a b16a and was wondering what the differences between the two are, is there something i have to do different with the PR3 when installing other then the PW0?
both pw0 and pr3 wiring is the same, not sure what makes them different other than i believe the pr3 was from the civic b16a and the pw0 was from the crx b16a. the wiring is connections are:
ecu connection engine connection
c8 2nd O2 sensor
a8 vtec solenoid
b5 vtec oil pressure
b19 knock sensor
hope that helps.
c8 2nd O2 sensor
a8 vtec solenoid
b19 knock sensor
hope that helps.
The processor code is different, even between the JDM and EDM versions. From the outside, they are the same, but if you put JDM PR3 code in an EDM PR3, no worky.
The PW0 is from civic's and crx's, the PR3 is from the Integra. Performance is the same between them.
The PR3 is slightly easier to chip and has more programs to choose from if you decide to modify it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz »</TD></TR><TR><TD CLASS="quote">The PW0 is from civic's and crx's, the PR3 is from the Integra.</TD></TR></TABLE>
damn, forgot about the integra, your right
PINKS
Dec 11, 2006 02:45 AM
PINKS
26
Dec 10, 2006 08:11 PM
