best non-vtec cams?
I hate everything
If you aren't going to raise your compression, then crower 403's would probably be a good choice for you. If you do raise your compression, then 404's would give you some nice power. Either choice should be installed with valvesprings and tuned for best reliability/results.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg »</TD></TR><TR><TD CLASS="quote">If you aren't going to raise your compression, then crower 403's would probably be a good choice for you. If you do raise your compression, then 404's would give you some nice power. Either choice should be installed with valvesprings and tuned for best reliability/results.</TD></TR></TABLE>
i believe it was styleTeG i talked to and in order for him to keep his crank pressure within stock tolerances with the 404's he milled his head .015...i think, he did this to keep keep the cams from overcamming the engine i believe
I agree with the post above.
Otherwise check out my sig or nonvtec.com
rewerbcrx
Dec 30, 2006 09:06 AM
The Destroyer
12
May 30, 2006 02:57 PM
VTECcnIT
Apr 13, 2006 03:34 PM
JDM2ndGen
20
Jan 9, 2004 07:04 PM
