Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
TURBOSMART Boost Controller is here ! even E-BOOST Version 2 Boost by gear, NOS switch, RPM Shift L
Old Nov 11, 2005 | 11:22 AM
Flamenco-T's Avatar
Default TURBOSMART Boost Controller is here ! even E-BOOST Version 2 Boost by gear, NOS switch, RPM Shift L
NO MORE ALLEN WRENCHES!!!
AND MORE OPTIONS FOR A DIFFERENT VARIATY OF APPLICATIONS THAN THE
COMPETITORS!!!
BOOST TEE
-Set your Boost and forget it
-Boost is fully adjustable from under the bonnet
-Detent System for ease of adjustment
-Gated System to bring boost on faster
-Can be mounted with an optional mounting bracket
-Mounting Bracket - BOOST TEE only
-Anodised billet aluminium
-Supplied with all mounting hardware
<FONT COLOR="red">$ 79.95</FONT>
IN CABIN
Designed to be mounted inside the cabin and allows for boost adjustment on
the run. Ideal for the active enthusiast.
-Control boost from the drivers seat
-Mounting bracket, hose and all fitting hardware supplied
<FONT COLOR="red">$ 139.45</FONT>
SINGLE STAGE
Compact design, will fit in the palm of your hand. This unit provides fast
boost response with one adjustable boost level. Ideal for turbo cars
without factory boost controllers. Switch between standard and high boost.
-High Boost setting is fully adjustable
-Includes Rocket Launcher Switch and fitting hardware
-Mounting bracket and fittings supplied
<FONT COLOR="red">$ 164.18</FONT>
DUAL STAGE
boost response with two adjustable boost levels. Just toggle between high
and low on the fly. Ideal for replacing factory boost controllers.
-Low and high Boost settings are fully adjustable
<FONT COLOR="red">$ 188.92</FONT>
E-BOOST Ver. 2
<FONT COLOR="red">$ 475.95</FONT>
<FONT COLOR="red">It's a tachometer</FONT>
-e-Boost2 displays RPM with a much greater accuracy than the common
analogue tachometer!
<FONT COLOR="red">It's a boost gauge!</FONT>
-With high accuracy boost and vacuum display, e-Boost2 outperforms most
analogue boost gauges!
<FONT COLOR="red">It's a shift light!</FONT>
-With an optional single or double LED ring, e-Boost2 controls up to 2
warning/shift lights!
<FONT COLOR="red">It's a NOS swtich!</FONT>
-With a fully programmable auxiliary output e-Boost2 gives you control over
water spray, methanol or nitrous injection!
<FONT COLOR="red">It's the mother of all Boost Controllers!</FONT>
-Up to 6 alternate boost mapping functions with specific boost mapping for
FWD, RWD, AWD, Bike and Drag racing applications.
-A specifically developed Correction Feature eliminates boost drop-off at
high RPM
-Boost levels can now be mapped against TIME or RPM
-Special gate pressure function eliminates wastegate creep
-Peak Hold/Max Boost Recall function monitors the boost and RPM
-The display can be configured to KPA, Bar or PSI
<FONT COLOR="blue">Features Accessories</FONT>
-Choice of 40 or 60-psi models
-Choice of bezel/face colour combinations
-Back-lit, easy to access function buttons
-Auto dimming
-Programmable audible warning alarm
-Advanced short circuit protection
-Suitable for panel, gauge pod or pillar mounting
-Easy to read, 7-segment display with bar graph
-Housing and accessories made out of tough, billet aluminium
-Single or double LED ring. Available in bezel-matching colours
-Shift/warning lights complete with a plug-in wiring loom, available in
four colours (Red, Green, Amber, Blue)
-Remote-mount shift light
-Dash mounting kit. Tough and sturdy with tilt and directional adjustment
<FONT COLOR="greeb">HERE'S HOW TO ORDER: </FONT>
Please add $ 6.50 for Ground Shipping and send the funds to;
paypal@fast-turbo.com
Call us directly and place your order, 877-988-8726 TODAY !!
Check and MO, please send them to:
Fast-Turbo.com
1150 Blue Mound Rd West
Suite 810
Haslet, TX 76052
Buy direct from an Authorized Distributor !, Fast-Turbo.com
thanks guys,
Stan/Tommy
Modified by Flamenco-T at 1:56 PM 5/15/2006
Old Nov 12, 2005 | 11:05 AM
StockBlockRob's Avatar
Default Re: TURBOSMART Boost Controller is here ! even E-BOOST Version 2 Boost by gear, NOS switch, RPM Shi
why have none of my emails been retunred about my order. going on two weeks here with no response or item?
Old Nov 14, 2005 | 03:53 AM
Flamenco-T's Avatar
Rob,
You really don't need to reply on 3 threads to get my attention. I am sorry for not responding in time as I have explained that we were in SEMA show. I thought you should've gotten a UPS treacking info directly to your email.
This is your tracking number and I took the liberty to tracked them.
1Z X3R 517 03 4004 057 0
In Transit -
On Time
Sched. Delivery: Nov 15, 2005
Shipped to: WESTMINSTER, MD, US
Service Type: GROUND
thanks
Stan
Old Nov 19, 2005 | 03:04 AM
D@nnY's Avatar
bump
Old Nov 20, 2005 | 07:34 PM
Flamenco-T's Avatar
thanks dude
Old May 15, 2006 | 10:48 AM
Flamenco-T's Avatar
uppity
Flamenco-T
Jul 21, 2005 12:38 PM
atl328ci
Jul 21, 2005 09:14 AM
Top Ramen
Jan 17, 2005 09:21 PM
