What PSI on BFG drag radials?
Im heading to the track tonight, and just picked up a set of BFG drag radials 205-50-14 and never launched with DR's or slicks before.
First time at the track ran 13.5@111, and 13.1@114 ran those times on my falkens 195-60-14 street tires.
Now im looking for better times with these DRs
Since the SEARCH is down now, what psi are you guys running at? and do you do a burnout in the box with DRs? 1st gear or 2nd gear?
thanks guys
thanks guys
wow that low huh? i woulnd't of thought to of gone that low, right now i got them at 30psi
but when i get to the track i'll let the air out, in the rear i got them at 40psi.
thanks for the input
but when i get to the track i'll let the air out, in the rear i got them at 40psi.thanks for the input
are you guys doing burnouts on these to warm them up? i've been reading to do them in 2nd gear? whats wrong with 1st?
or just going around the box and doing a dry hop to shake loose the debri?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djmota »</TD></TR><TR><TD CLASS="quote">do the burn out. and 15 psi is a nice starting point. If your car can pull a 2nd gear burnout then go for it.
more rotation more heat better grip. </TD></TR></TABLE>
thanks for the pointers guys...appreciated it.
heading to the track in 45 mins
more rotation more heat better grip. </TD></TR></TABLE>thanks for the pointers guys...appreciated it.
Well just got back from the track, only got 3 runs
1st run BFG's at 15psi, 2nd gear burnout, launch 4k:
60ft: 2.254 13.37@110.23
2nd run BFG's at 14psi, 2nd gear burnout, launch 4.5k:
60ft: 2.188 13.05@112.54
3rd run BFG's at 14psi, not a great 2nd gear burnout, launch 4.5-4.7k:
60ft: 2.145 13.03@112.94
I so wanted into the 12's today, but i guess since it was cold out i think top of 1st gear i would lose traction and i could do a better launch probably.
well only one more week before the track closes, so im hoping to get back there one more time and try to dip into the 12's
btw specs on the car, 280hp 217ft-lbs 2450 with me in it
Would launching higher yield a quicker time? Or is more seat time the only fix for 12's?
thanks fellas
thanks fellas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_crx »</TD></TR><TR><TD CLASS="quote">whats your setup?</TD></TR></TABLE>
dohc-t swap into eg hatch hondata tuned ran at 9psi, sorry if i don't want to reveal too much im wary of theives who lurk the boards. had my gf's car stolen off my driveway few years back. don't want to take chances with my baby.
theives
theivesThread
