is this my main relay? going to junkyard soon need answer
no, it's up and to the left
you'll know it when you find it because it's really hard to get to and it's bigger than that. it also has a metal mounting bracket permanently attatched to the outer housing of the relay.
If you are sitting in the driver seat, it is under the dash between your left leg and the door, at about knee level.
From: I told you to wait in the truck in Texas, United States
The item you selected is the clutch interlock relay..
What you are looking for is hidden behind the coin tray in the dash..
See: http://honda.hybrids.jp/tech/p...shtml
ya my main relay blew also, and its behind your coin tray to the left - black box . i just went to the Junkyard and got a one its better then paying $60 when u can just get one for free
If you can solder, pry the tabs apart and take the cover of the relay off. Look for cracked solder joints at either end of the circuit board. I usually find the same 4 are cracked. (2 on each end) I use solder wick and pull the old solder off, then resolder the connections. Clean off the resin that the solder leaves and it's like new.
turns out the main relay wasn't my problem. go here for the whole story if you are interested...
https://honda-tech.com/zerothread?id=1428869
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">everyone that works for honda knows to re-solder.
People at honda are shady sometimes. Take your dizzy off, clean it up real good, put a new coil in, then charge you for a new dizzy
</TD></TR></TABLE>People at honda are shady sometimes. Take your dizzy off, clean it up real good, put a new coil in, then charge you for a new dizzy
deadhead23
Jan 15, 2021 10:43 AM
