HELP!!!!!! Broken sun roof switch, sun roof OPEN!!!!
Over the last 2 days I have been trading complete interiors with another Integra owner. When we took his sun roof switch out of his dash to put in mine (my car doesn't have a sun roof) we broke the switch. Is there any way to close the sunroof without the switch? It looks like it is going to rain tonight, and its open! HELP!
The car should have a sunroof wrench. It is kept where the spare tire jack is located. Above the rear seat, in the middle of the roof, there is a little round plastic covering. Pop that out and use the sunroof wrench to crank it closed.
BTW: Why are you putting a sunroof switch in your car if it does not have a sunroof?
-RedTeg
We put the switch in my old Tan dash that is going in his car. The sun roof is stuck with the back part of the glass up, not wide open. Will the wrench still close it?
can you not jump the wires still in his car to make a connection similar to wah the switch does....that should be all you need to do
did you read what redteg said!!? theres a wrench that normally comes w/ the car to close it for this very type of emergency, i believe it just an allen type on the wrench anyhow.
included w/ every car that comes w/ a sunroof (unless you bought it used and the previous owner lost it/didnt give it to you) is a S looking wrench to close the sunroof in the case of an emergency where the motor doesnt work or you otherwise cant close it (broken motor, broken switch, dead battery, etc.. ).. it should be in your spare tire well w/ your lug wrench and jack tools..).. inser that into the hole in the headliner and turn it manually..
