Low Compression pistons pass CA smog?
Old Nov 10, 2005 | 10:32 PM
aznwash3wboi's Avatar
Default Low Compression pistons pass CA smog?
I originally posted this in F-I forum and got no replies....I want to put some low compression CP pistons (9:0 c/r) in my GSR.... but i want to be able to take my turbo kit off and pass smog just in case my smog hookup goes away..... anyone running low compression and passing CA smog?
so basically i want to know if a stock GSR with lower compression will pass CA smog.....
Old Nov 10, 2005 | 11:21 PM
Default Re: Low Compression pistons pass CA smog? (aznwash3wboi)
talked to a smog tech... it will pass...
Old Nov 11, 2005 | 03:55 AM
shamoo's Avatar
Will you make something up for me please?
Your emissions numbers WILL be different than a stock GSR. Compression is a very important number during combustion, and plays a large role in the combustion characteristics. Your stock compression and ECU/fuel/air/timing/etc settings were all meticulously set by engineers, if you change it, those will change possibly altering your emissions.
You may or may not pass. I'm sure the "tech" was just assuming it will read similar to a car that came stock with 9.0:1 compression.
Old Nov 11, 2005 | 07:53 AM
temp's Avatar
Default Re: Low Compression pistons pass CA smog? (shamoo)
my answer is no, you will not.
Old Nov 11, 2005 | 02:36 PM
Default Re: Low Compression pistons pass CA smog? (temp)
i told him it would be lower compression from stock GSR.... from 10:1... he said it would pass.... iono.. i will just take my chance i guess...
Old Nov 11, 2005 | 03:02 PM
adseguy's Avatar
if it only a couple tenths of a point in compression you'll be fine otherwise you have to change your timing in order to not produce too much NOx( too much timing) or toomuch hydrocarbons (not enough timing). If you notice you have one too many Nox emissions then you know to reduce timing and vice versa..otherwise no problem to pass. I made a post on how I passed with my car without CAT and I passed with flying colors. I have a few tips on how to do it to
efit: without a cat
Modified by adseguy at 12:00 PM 11/12/2005
Old Nov 11, 2005 | 03:29 PM
ricebucket's Avatar
Default Re: Low Compression pistons pass CA smog? (adseguy)
my ls-vtec passed smog as a LS...the tech didnt know the difference so I passed visual...in case people start flaming. I passed on 2 differenet occasion, once with b16 pistons another with itr pistons.
Old Nov 11, 2005 | 03:35 PM
temp's Avatar
Default Re: Low Compression pistons pass CA smog? (ricebucket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricebucket &raquo;</TD></TR><TR><TD CLASS="quote">my ls-vtec passed smog as a LS...the tech didnt know the difference so I passed visual...in case people start flaming. I passed on 2 differenet occasion, once with b16 pistons another with itr pistons.</TD></TR></TABLE>
ok but that does not relate you had HIGHER compression, he dropped a whole point on his compression
Old Nov 11, 2005 | 05:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">if it only a couple tenths of a point in compression you'll be fine otherwise you have to change your timing in order to not produce too much NOx( too much timing) or toomuch hydrocarbons (not enough timing). If you notice you have one too many Nox emissions then you know to reduce timing and vice versa..otherwise no problem to pass. I made a post on how I passed with my car with CAT and I passed with flying colors. I have a few tips on how to do it to </TD></TR></TABLE> im all ears! bring those tips..... remember im in CA.. i think the most strict smog laws in the US
Old Nov 12, 2005 | 09:03 AM
adseguy's Avatar
https://honda-tech.com/zerothread?id=1305346
without CAT by the way....I wrote with cat on accident
Old Nov 14, 2005 | 08:47 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1305346
without CAT by the way....I wrote with cat on accident</TD></TR></TABLE>
thats fine and dandy but you are in IL and we are in CA, CA is the most strict state when it comes to emissions
Old Nov 14, 2005 | 09:32 AM
adseguy's Avatar
Unless you are just changing pistons or have a Greddy kit, In CA you won't pass the underhood inspection because it needs to be CARB approved. All my tips though will help on your low compression GSR especially the timing part, because that WILL be off. GL either way
Old Nov 14, 2005 | 10:01 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">Unless you are just changing pistons or have a Greddy kit, In CA you won't pass the underhood inspection because it needs to be CARB approved. All my tips though will help on your low compression GSR especially the timing part, because that WILL be off. GL either way</TD></TR></TABLE>
lol i know plenty about california smog, again, he wont pass, not without significant adjustments
Old Nov 14, 2005 | 06:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">Unless you are just changing pistons or have a Greddy kit, In CA you won't pass the underhood inspection because it needs to be CARB approved. All my tips though will help on your low compression GSR especially the timing part, because that WILL be off. GL either way</TD></TR></TABLE> yea mna... thanx ill try them...
Old Aug 1, 2007 | 12:00 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
resurrecting this thread from the dead to get more opinions. i will be doing the same.
Old Aug 1, 2007 | 12:39 PM
thewrai6th's Avatar
Default Re: Low Compression pistons pass CA smog? (JDM turbo DC)
Talk to the OP about his results. But legally, NO this will not pass. No internal engine modifications were ever CARB approved.
Will it pass the sniffer? Probably.
Old Aug 1, 2007 | 01:01 PM
Default Re: Low Compression pistons pass CA smog? (thewrai6th)
I wanna know the chances of it passing the sniffer.
Old Aug 1, 2007 | 02:05 PM
hmongyaj87's Avatar
if other people on ht could pass smog with a higher comp. piston like itr or p30 (b16) then i think you should be able to pass with lower comp. isn't 9-1 ls comp.?
Old Aug 1, 2007 | 07:23 PM
thewrai6th's Avatar
As long as your o2 sensor(s) is not disabled or fouled, and your tune is not too rich or lean, it should pass the sniffer. All of the other emissions crap has to be hooked up also.
Old Aug 2, 2007 | 12:51 AM
Default Re: Low Compression pistons pass CA smog? (hmongyaj87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongyaj87 &raquo;</TD></TR><TR><TD CLASS="quote">if other people on ht could pass smog with a higher comp. piston like itr or p30 (b16) then i think you should be able to pass with lower comp. isn't 9-1 ls comp.? </TD></TR></TABLE>
yea but the air/fuel is tuned to that stock compression. the gsr ecu is designed to run 10:1 compression pistons.
Old Aug 2, 2007 | 08:29 AM
thewrai6th's Avatar
Compressing the mixture does not change the ratio of fuel:air. Your o2 should put you at stoch when crusing anyway. I think timing would be the issue here (if there is an issue).
Old Aug 2, 2007 | 09:41 AM
deftonerider's Avatar
ummmm they have no way of knowing what is inside his engine and if your car passes the visual and you tune it to pass the sniffer and assuming you have a integra gsr for that gsr motor than you should be fine
unless you look sketchy or are a dick a lot of smog techs don't even look at visual or timing
but if he checks you timing and its been tinkered then he will fail you
Old Aug 2, 2007 | 12:44 PM
SIC_jdm_da9's Avatar
well to pass CA smog that i know of is to get your motor cold and you will pass... thats how i passed
_inline4turbo_
Apr 30, 2009 08:06 AM
kirby_lys
Feb 1, 2007 11:59 PM
aznwash3wboi
Nov 10, 2005 08:44 AM
obd1gsr
Apr 3, 2004 09:17 PM
