clutch pedal feels rough after pushed in 75%
Old Nov 10, 2005 | 09:04 PM
pr0phet's Avatar
Default clutch pedal feels rough after pushed in 75%
it’s almost as my clutch pedal has a second level or something, but it starts feeling very rough after I push it in around 75%. Once I push it in all the way, it stops doing it until I totally take my foot off the pedal. I’m guessing it’s got to do with the pressure plate. What do you guys think?
Old Nov 11, 2005 | 11:37 AM
pr0phet's Avatar
Default Re: clutch pedal feels rough after pushed in 75% (pr0phet)
up
Old Nov 11, 2005 | 12:12 PM
Wayne_Curr's Avatar
Every clutch seems to do its own thing, is it lacking performance?
Old Nov 11, 2005 | 02:30 PM
Da9teggy92's Avatar
i would say its the throw out bearing
Old Nov 11, 2005 | 06:17 PM
pr0phet's Avatar
Default Re: clutch pedal feels rough after pushed in 75% (Wayne_Curr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wayne_Curr &raquo;</TD></TR><TR><TD CLASS="quote">Every clutch seems to do its own thing, is it lacking performance?</TD></TR></TABLE>
no.. performance is 100% fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Da9teggy92 &raquo;</TD></TR><TR><TD CLASS="quote">i would say its the throw out bearing</TD></TR></TABLE>
so what would I need to get to fix it? pressures plate? disk?
Old Nov 11, 2005 | 07:48 PM
Sack Master's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Da9teggy92 &raquo;</TD></TR><TR><TD CLASS="quote">i would say its the throw out bearing</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr0phet &raquo;</TD></TR><TR><TD CLASS="quote">so what would I need to get to fix it? pressures plate? disk?</TD></TR></TABLE>Are you serious? If it is the throwout bearing(and I'm not saying it is) than you would need to get a new throwout bearing.
Old Nov 12, 2005 | 03:15 PM
Da9teggy92's Avatar
if it is the throw out bearing, then you would need a new one. so you would have to take off the tranny to do it. so i would say if you do, do it then mine as well just change the clutch seeing that the tranny is off. but before you do that i would inspect the clutch cable. maybe take it off and grease it up.
STEVE-O7
Oct 10, 2007 05:18 PM
itr1235
Apr 11, 2007 11:17 PM
ic89
Oct 17, 2006 11:59 AM
pli
Sep 1, 2006 04:09 PM
AspectIndustries
Jan 5, 2004 07:49 AM
