ok , i let me clutch out and it takes like 2 sec to engage?? what happened?
Old Mar 10, 2002 | 04:50 PM
civicracer1993's Avatar
Default ok , i let me clutch out and it takes like 2 sec to engage?? what happened?
well i have a cable clutch on my 5 spd tranny.. its in a Civic DX .. when i let the clutch out normally if i try itll chirp in 2nd gear.. well now my clutch takes like a second extra to even engage... its done this before but usually goes back to normal after like 30 min.. what happened and how can i fix it???
mike
Old Mar 10, 2002 | 04:54 PM
87posCRX's Avatar
Default Re: ok , i let me clutch out and it takes like 2 sec to engage?? what happened? (civicracer89)
im guessin your clutch is worn out
buy a new clutch
Old Mar 10, 2002 | 05:31 PM
tdc's Avatar
tdc
it looks like you were chirp`n a little to much time to lok for a new one (clutch)
Old Mar 10, 2002 | 06:03 PM
kranked91dx's Avatar
She is dead!!,
get a new one!!
Old Mar 10, 2002 | 06:35 PM
if its dead then why does it "magically " go back to normal in like 30 minutes usually?? could it just b overheating.. also how much about would a stage 2 or 3 clutch b?? anyone got one for sale??
thanks
mike
oh yeah.. what about the little adjustment **** for my clutch.. its a cable clutch.. does this have anything to do with it?cause i can turn it and make it loose or tighter...
Old Mar 10, 2002 | 09:12 PM
Louie B.'s Avatar
is it slipping or just plain not engaging, your cable could be binding up. or it could be like mine, I aparently have an oil leak somewhere in the vacinity of my clutch, if i run the engine over 5000 rpm, it starts leaking, and the clutch starts slipping. If I take it easy for a while, the oil burns off and it starts working fine again. I'm just gonna drive it like a grandma 'tll I do a swap.
Old Mar 10, 2002 | 10:23 PM
Gasoline Fumes's Avatar
thanks
mike
Loosen the cable. There should be some freeplay in the pedal.
danno33
12
Sep 30, 2012 08:46 PM
danno33
Jul 14, 2009 07:45 AM
MichealSenior
Feb 17, 2009 12:56 AM
djsire
Sep 7, 2005 04:14 PM
wumba
Feb 13, 2005 07:42 PM
