broken motor mount
Last time i was at the shop I was told that my motor mount was broken. This is the one closer to the pasanger wheel. What should I do about replacing this or what not. Do i need to replace the whole mount or can i get it refilled or something?
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquidgsr »</TD></TR><TR><TD CLASS="quote">any benefits with going for a hasport?</TD></TR></TABLE>
It would just the hold the motor in there stiffer I believe, like if you take it to the track, the engine wouldn't move as much.
If you just daily driving, the stock mount will be fine. I bought all 4 OEM mounts for my G2 for 234 and change, that included tax.
I hate everything
Yeah, there not much from the dealer at all.
I broke the same mount on mine, it was broken for awhile, so depending on how long yours has been broken, it can put stress on the other, 3 or 4(if you have a G3) if this is the case, might want to look at replacing those as well. I decided to do all 4 on mine, just cause the car has 200k on it.
You know if there bad/going if the engine shakes pretty rough at start up or when you just take your foot off the accelorator and you get alot of vibration from the engine bay.
hth
hth
yeah i get a rough start up and do get a lot of shaking when letting off the accelerator...thought that was normal. I guess i will look into changing all the mounts maybe...but stick with this one specially for now. If it doesn't help a lot then i will go ahead and do the rest. Thanks.
I hate everything
This is the tranny mount correct? Because that is the one that is broken on mine. I have an AT. When i sit at lights w/ the car in gear, sometimes i get a nasty vibration, like the whole car vibrates, really annoying, and I know it's because of the busted mount.
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquidgsr »</TD></TR><TR><TD CLASS="quote">have any idea what number part it is?</TD></TR></TABLE>
Actually, 1 sec here.....what year of integra is it?
