dc2 front camber.
does anybody know if u need a camber kit to adjust the camber on the front tires for a dc2. its not very far off, just wanna find out before i go out and buy one. thanks guys.
If you lower the car a whole lot it will result in lots of negative camber, then you would neeed a kit because there is no adjustment on the DC2.
But if it is not too far off, then I wouldn't worry about it too much. Keep an eye on tire wear, but you often don't have much problems with inner wear unless you have a lot of negative camber.
E36 Guy
16
Apr 7, 2006 09:58 AM
