Rear camber correction?
I've hit a search on this just a while ago and I can't find it. I am looking for the site that tells you where to add washers, how many washers and what bolt to use in the rear suspension to correct the rear camber. Does anyone here have that site bookmarked, or knows any other similar websites?
Thanks in advance
Thanks in advance
i just looked its not there anymore but its very simple and cheap, just remove tire, unbolt the control arm and put 1-2 washers depending on how low you are, correct me if i'm wrong anybody i did it a long time ago
it can take a lot of washers.. last time I did mine it was about 4 washers on each bolt (the screw was basically maxed out) to get it into specs (it about -.75 deg)... that was on a 2" lowered dc2...
you really have to go to an alignment shop to have it measured after you do it
Thanks guys... what I was really looking for was the type of washers used, and the # of washers I should use. The problem is that there are washers with different thicknesses
the ones I used were called "fender washers" I got them at home depot in the nuts 'n bolts section
it seems to me that when I used 4 is was prolly close to 1/2 inch thick
[Modified by Phoenix GSR, 12:43 PM 3/11/2002]
spencedogg
14
Dec 7, 2003 01:14 AM
