on toda spec A's
i will be installing some toda spec a cams with a pair on spoon cam gears.. the question is i have to wait a lil to tune them.. in the mean time should i just stick with my oem ecu or do u suggest running my neptune tuned ecu(basically the same as hondata) . neptune was tuned with oem cams and cam gears with i/h/e..
just run the neptune and see how it goes....if you want after you do the install i will run my car against yours on highway to see the difference before tuning...
since i still have stock cams it should be good to compare...
I would recommend running the stock ECU and raising the fuel pressure a small amount. Obviously, you'll also want to go rather easy on the motor until you have the opportunity to get it tuned.
Black R
Oct 22, 2004 04:30 AM
