93 Dash conversion to GSR
Old Nov 10, 2005 | 10:22 AM
IntegraGen2's Avatar
Default 93 Dash conversion to GSR
Will a gsr dash fit into a 93 ls... and how hard is it if it is possible to do... hit me up wit the info... thanks...also can a 97 type r cluster fit into my 93 ls....
Old Nov 10, 2005 | 10:28 AM
BlackDAy's Avatar
Default Re: 93 Dash conversion to GSR (IntegraGen2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraGen2 &raquo;</TD></TR><TR><TD CLASS="quote"> Will a gsr dash fit into a 93 ls... and how hard is it if it is possible to do... hit me up wit the info... thanks...also can a 97 type r cluster fit into my 93 ls....</TD></TR></TABLE>
gsr from what year? 92-93? yes. 94+ i dunno about that. i know u can get the cluster to fit/work but i don't know about the dash. why don't u just keep the dash u have?
Old Nov 10, 2005 | 11:37 AM
stillrockin18s's Avatar
If you are getting a 92-93 GSR dash for you 93 (GS, RS, LS) Integra there really is no difference, save your money unless you are doing a interior color swap.
As far as a G3 Dash goes in a g2, I've never seen it done, but where theres $ and a will, there is a way.
As far as the ITR cluster, I have seen it done a few times, you need the cluster, an electric speed sensor, a 94-00 Integra cluster bezel, tools and fiberglass and a few other things. I saw it on http://www.g2ic.com, maybe go there and do a search for ITR cluster or something to that nature.
Hope this helps....
Old Nov 10, 2005 | 12:01 PM
mugenspoongsr's Avatar
Default Re: 93 Dash conversion to GSR (lowriden_acura)
bump
Old Nov 10, 2005 | 12:09 PM
Default Re: 93 Dash conversion to GSR (mugenspoongsr)
ITR Cluster swap (g2ic.com)
http://www.g2ic.com/forums/sho...uster
Old Nov 10, 2005 | 12:11 PM
adiDAs's Avatar
g2 dash looks nicer than g3 imo
Old Nov 10, 2005 | 12:23 PM
91JDM1nt2B's Avatar
Like this. Had to rewire all the wires to the new plugs. Make brackets to mount to the dash. Mold the back part of the DC bezel to the front part of the DA bezel. Convert to VSS speed signal. I've posted the wiring on G2iC a few times so far. http://www.g2ic.com/forums/sho...34881
Modified by 91JDM1nt2B at 7:05 PM 11/14/2005
Old Nov 10, 2005 | 12:30 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: 93 Dash conversion to GSR (91JDM1nt2B)
so nice, I wish I had time to do that lol...
Old Nov 10, 2005 | 02:47 PM
Its a 94 + dash gsr..... i want something that noone has yet....
Old Nov 10, 2005 | 02:54 PM
bg-33p's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraGen2 &raquo;</TD></TR><TR><TD CLASS="quote">Its a 94 + dash gsr..... i want something that noone has yet.... </TD></TR></TABLE>
well obviously someone already has this...so look up what 91JDM1nt2B posted
Old Nov 10, 2005 | 02:56 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Youre question is pretty vague. But in a nutshell, here's your answer:
Will DC dash fit in a DA?: No
Can a DC dash fit in a DA?: Yes
Is it hard?: Yes
Now go buy a DC dash and knock yourself out.
Old Nov 10, 2005 | 03:17 PM
91JDM1nt2B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraGen2 &raquo;</TD></TR><TR><TD CLASS="quote"> ...also can a 97 type r cluster fit into my 93 ls....</TD></TR></TABLE>
Well I answered that question. My dash is a 90-93 integra dash, with the 97 jdm itr cluster. There's a few other people that I know on G2IC that have done this using the usdm DC clusters. I don't know if they ever got around to molding the bezel to fit though.
As far as a DC dash in a DA, well all the mounting points are different, and it's probably a different contour to the windshield. So it would look fucked up in there unless you did a lot of work to get it to fit. Plus all the ac/heater panel cables would have to all be redone. The DC dash does look hot though, with the passenger airbag delete tray.
Old Nov 12, 2005 | 05:06 PM
Default Re: 93 Dash conversion to GSR (carma_626)
teggysue.... the picture only shows the itr gauges in a dc...i know that people have that but noone has a dc dash in a da... look closer
Old Nov 13, 2005 | 12:25 AM
bg-33p's Avatar
thats a da dude, my dc dash doesnt look like that lol
Modified by teggysue at 3:11 PM 11/13/2005
Old Nov 14, 2005 | 09:54 AM
91JDM1nt2B's Avatar
IntegraGen2,
Look closer. That is a G2 dash, with a 97 jdm itr cluster. I should know cause it's my dash. I installed that **** and rewired everything, and coverted the speedo to vss.
Here's a pic before I finished the bezel.
ERATIC
Nov 1, 2007 10:32 AM
ugot8up
Nov 25, 2004 02:53 AM
litterbox
Sep 13, 2004 08:04 PM
visionsOFmadness
Jul 19, 2003 02:06 PM
